After the Chinese New Year, I will be working on developing 7*XHP70.2, using 3 21700 in series, which can be charged with a charger with PD protocol (15V or 20V charging)
Congratulations, off to a good start for the new year. Will that L8 body tube fit the M3 and M3-C? The part going into the head looks slightly thicker than the L6/7 series. Is that 26980 extension tube compatible with anything else, like one end or the other of the M3, L6/7? Looking forward to when the 3*XHP70.2 goes on sale. Yes, looks like a very good start 2022.
Simon, could you please make it possible to disable mode memory and allow ramping up from moonlight mode on the M21F and models with similar drivers? I think these features would be really appreciated, not only by me.
Simon, can you tell me what is happening with my 8A driver? Instead of the highest 100% mode I have some low pwm mode. I had it in S11 but I put it to S21B. I did not check if it was like that from the beginning. I thought it was a battery, but I have a new Molicel P42 fully charged now. I have that in every group. In the video, the first group and the change to the second one. After a pause, group 10.
Is there going to be an xhp50.2 3v version with op reflector for the new M21F? Should be a more efficient and usefull high lumens close to medium range light with a wide hotspot rather than as a thrower imo especially with the e-switch.
