Pulled the trigger on one yesterday. I have been waiting on this 24 amp model for awhile.
I have two of the older DPS models which have been great but I really wanted this newer better display model.
The on and off membrane switch on the DPS model was a little hard to push, sometimes the whole power supply would move just trying to activate the on switch. Hoping this one is much easier.
I’m using a 95W laptop power brick (20V) to power my DPS5020, which has been sufficient for 4.2V20A.
I also have a meanwell 48V4.5A which I’ll be using with the RD6024, I don’t need the full 60V24A power, so that’ll be sufficient for my use.
I probably won’t ever utilize both 60v and 24a but that doesn’t stop me from wanting it. I use my RD6012 for electrochemistry and it’s been great for that, more likely to use higher voltage than high current in that application, I am just being picky.
That looks nice, I can’t find max dimensions for a power supply in the S800 case, but it’s very close in size to the one RD has listed on AliExpress so maybe it will fit?
for RD series power supply, use the green and black terminals to charge battery, only when you connect it in the right way, it will charge, if you connect it in the wrong way, it will not charge even you turn on the output
according to our PSU size 241*125*65mm, after install it there is not much space, so I do not know if this power supply can be put into the S800 case because its size is L250*W135*H70mm.
it came so quickly, the quality of the product is on top, I am delighted with this device ! The seller answers all questions, the packaging is powerful and withstands Russian mail. Take it, you will not regret it.
