I’m using a 95W laptop power brick (20V) to power my DPS5020, which has been sufficient for 4.2V20A.
I also have a meanwell 48V4.5A which I’ll be using with the RD6024, I don’t need the full 60V24A power, so that’ll be sufficient for my use.
I probably won’t ever utilize both 60v and 24a but that doesn’t stop me from wanting it. I use my RD6012 for electrochemistry and it’s been great for that, more likely to use higher voltage than high current in that application, I am just being picky.
That looks nice, I can’t find max dimensions for a power supply in the S800 case, but it’s very close in size to the one RD has listed on AliExpress so maybe it will fit?
for RD series power supply, use the green and black terminals to charge battery, only when you connect it in the right way, it will charge, if you connect it in the wrong way, it will not charge even you turn on the output
according to our PSU size 241*125*65mm, after install it there is not much space, so I do not know if this power supply can be put into the S800 case because its size is L250*W135*H70mm.
it came so quickly, the quality of the product is on top, I am delighted with this device ! The seller answers all questions, the packaging is powerful and withstands Russian mail. Take it, you will not regret it.
today is the last day we work, after today we will have 14 days holiday, we will back to work at Feb 8th and send packages according to the order date, please notice that
hello, we come back to work today. and the orders in the last 14 days will be sent out by the order date, please wait for the package coming, if you have any needs or questions, you can contact us rdtech.aliexpress.com
I bought it on January 8 with the launch discount, I shipped it on the 13th and it arrived on the 24th, I received it on the 26th very well packaged and without problems, I unpacked it
Arrived in 20 days, packaged well. The block itself is normal. Added languages Russian, German, French, Russian curve.There are several output options. Connecting to the power supply is somewhat inconvenient,the connectors that are included
