Personally I notice green tints more than moderate CRI. So I find myself preferring say an XPL HI over a 219C; however, I just started experimenting with minus green filters. They have pros and cons, but a rosy SST20 4000k is a beautiful thing.
I understand the question completely.
Maybe you should rewrite the question and the choices to choose from.
I edited the poll choices to help you not be confused.
That's nice, but it doesn't change the choice I made in the poll.
Also, I'm not confused here.
EDIT:
I see that you changed the choices again.
I like the choices much better now.
Congrats on improving the wording of the poll.
I don’t know exactly why some beams are just so much nicer than others but some just are. You know it when you see it. They just make everything warm and inviting. All my high CRI are the LH351Ds and none fit that category for me. Unless run on turbo they are generally green/grey looking to me. Not trying to be contradictory, just my opinion. I vote #2.
I just ordered two high CRI LED flashlights, to experiment, but I don’t think it matters unless you’re in the woods. And a recent post by fogfwar (What about the CRI hype (color rendering index) - #173 by fogofwar) showed to me that CRI alone isn’t the “be all, end all” of the flashlight world.
And like raccoon city pointed, even though CRI might be important, efficiency is also something that cannot be ignored.
I’ve always viewed them as tools to see things in the dark.
Chris
I chose no and I stand by that. However, I like a high CRI light and certainly don’t think that more lumen is always the answer. Tint and beam are where its at
My eyesight is so bad that yes it matters to me. I find that having the best color definition really makes up for some discrepancies.
only 100+ CRI for me
I voted Yes
because I do not need bright light
I need nice light
I voted yes, but I need high CRI only at close to mid range. I don’t care when it comes to throwers.
It depends on the light. For general use, EDC, and headlamps, I want high CRI. For throwers & mega flooders, low CRI is fine.
Depends on the use case. Not important for walking the dog, outdoor activity, running, working etc. Lumens and sustainability is often more desireable. But we agree, the sw45k is highly pleasureable. I also like the sw50 of the TIP CRI. Nice keychain light.
Hi cri is extremely important to me but so is cct and form factor,clip ect and the UI and the beam pattern. Sometimes we must make sacrifices. 80 cri is about my current bottom limit. I edc two lights. My primary is 4000k and 92+ cri and the secondary light is 4000k and 82 cri. I have many others that are higher or lower that I use for brief periods but certainly not daily. Sometimes I pull some out to use for specific tasks just to remind myself of why I don’t like them. Or if I get a new light a bunch will come out for testing in the house and in the backyard.
I prefer high CRI. Back when I got hooked on lights I did want the most lumens I could have. It was just a thrill after the previous low output, mass market, cheapy lights I had. It took a while but my preference for higher CRI grew and grew. But I willingly make do with lower CRI throwers.
You only live once. High CRI for me. It actually helps with decisions since it eliminates so many choices.
How soon we forget all our lights used to be 100 CRI. It's like people who get used to low bitrate MP3 files. It still sucks, regardless of your perception.
It’s like people who get used to low bitrate MP3 files. It still sucks, regardless of your perception.
A good way to find out how crappy your existing MP3 collection is, is to get a decent headphone amp and a nice set of monitors.
You’ll definitely have a hard time enjoying low bitrate MP3s then. I went through this. And again when I started collecting vinyl.
Not to get too far off topic, but it's the same with audiophile equipment and TV's. You'll have people spending thousands on quality audio gear and the latest OLED TV, only to use 80 CRI bulbs in their house. I don't fault them though - that's all most stores carry. But if you're a member of THIS forum....
For as long as us consumers are willing to buy more and better flashlights, CRI will increasingly be a part of the mix. The average Dept. store manager looks at sales and finds that customers seem to like the newer high CRI lights, even if it’s a subconscious choice. Profit drives innovation. If the consumer can get a better flashlight than the one sitting in the kitchen drawer when it wears out, why not, especially if it doesn’t cost much more. Personally I’m looking to get one of those new x-ray flashlights. Turn it on and see your bones (smile).
So, to sum it up and in my opinion, higher CRI beams are on the way. Maybe one day there will be a small high output zoomie that has no artifacts/aberrations, with perfect intensity across the beam, with sunlight CRI, and a small nuclear battery that lasts for a hundred years. Hahaha, outlandish dreamers get the cherry pie and whipped cream right?
CRI is an important factor for me when I choose my flashlights.
… but only up to a point.
- For example: I recently tried out my old Zebralight SC62D. It’s high-CRI… but at only 200 lumens, the beam is vastly inferior to my 80-CRI SC62w which produces well over 1,000 lumens.
- I’ll go for high CRI if I can get it in the correct tint, and if I don’t sacrifice too much output. I’m willing to sacrifice maybe 1/3 of the max output to get high-CRI. But if I have to sacrifice more than that I’ll probably just get the lower CRI option.
- It should be noted that even among “low CRI” there is considerable variation. 65 CRI may look horrible, but 80 CRI can look pretty good.
- For some specialist lights, low-CRI is the superior option. Oslon White 1 in a dedicated thrower for example.
When it comes to high-CRI, I prefer certain LEDs:
- SST-20 4000K is my favorite, but unless you get a really good bin most are unpleasantly greenish. To date, the best I’ve found were the FD2 bin sold by Kaidomain from their previous reel. What they’re currently selling as FD2 must be from a new reel. They claim it is also FD2, but the leds from it look greenish and nothing like the ones from their previous reel. I don’t think they’re really FD2. Unfortunately, I don’t know of any source that sells proper FD2 bin LEDs that don’t look greenish at present.
- LH351D is ok, but I’m not a huge fan since R9 is low and the beam pattern is a bit too floody. Slicing it solves the flood, but does nothing for the lousy R9.
- Nichia 219C is ok. A bit less output than LH351D, but has a pleasant beam pattern and adequate output. R9 isn’t great though.
- I do not like Nichia 219B… and that includes SW45K others on BLF like so much. The sacrifice in output is simply too great. Every time I try Nichia 219B in a light, I end up taking it right out again as I can’t stand the low output.
