Its a juggling act, in flashlights i want lumens. But low CRI (like 65) sucks.
In recent years getting 80 CRI or higher is achievable and you can still get lots of lumens.
My beater light is an FC11 with the high CRI and 1200 lumens, a good EDC.
But in a specialty light like max throw or most lumens i will sacrifice CRI for more brightness.
The right tool for the right job.
I didn’t think CRI would matter much to me, but surprisingly it makes a big difference when working on something. The contrast, perspective, and ease on the eyes is markedly improved with high CRI emitters like the SST-20 4000K, LH351D 4000K and 5000K. Now, high CRI is a requirement for me on new lights.
90+ CRI is important to me but it’s more than just CRI that matter. The DUV must be below the BBL otherwise even if it was 100 CRI with positive DUV (Green tint), I still would not buy.
Sure, for 99% of situations I use a light for there isn’t a tradeoff. High CRI LEDs are available in color temperatures I like that are bright enough to meet my needs, so no need to waste time with something that isn’t. I EDC a D4V2, and it spends most of it’s time set from 50-100 lumens if I had to guess. On the rare occasions I need more output (I think I’ve only actually NEEDED a thrower twice in my life) I can grab a light that meets that need.
Not sure if this is such a great example for flashlights. I have a bunch of old vinyl that I took care of back in the day and a reasonably good turntable and cartridge. Have nothing digital that comes close for sound quality. (I know it does exist, I just don’t own anything that high end.) I know that the mp3 and even AIFF files that I have on my computer and phone, which I can play through the same amp and speakers as the vinyl, just won’t have the full audio quality of decent vinyl. Would I give up listening to music on my phone with OK headphones? Absolutely NOT! Way too many additional benefits for one deficit.
While CRI is not my top factor in choosing a light, when it is combined with a pleasant tint and good optics, you just get a better light with no meaningful downside. Sure there are applications where this may not always be true but for most flashlights it is. I have about 100 vinyl albums worth of songs on my phone. I have about 100 vinyl albums in my office. Truly enjoy listening to music and using my flashlights while walking the dogs. Bringing along 100 albums for the quality of audio…
mp3 < vinyl < lossless (CDA) for audio range. Good equipment does make the difference, but each has their place.
low CRI < High CRI for visuals. Each has their place. I’m not worried about accurate colour rendition at 250M, I just want to be able to see what is there as clearly as I can.
Actually, I wouldn’t be a bit surprised if a lot of people just considered a nice tint to be high-CRI.
Throw in angular tint-shift and a fried-egg beam, warmer/cooler CT, etc., and an ugly-ass beam might be high-CRI that people hate, but a clean but lower-CRI beam looks soooooooo nice.
I chose ‘yes’
I remember a time when only one guy was using HCRI LEDs in his lights, McGizmo.
He was a visionary.
Now we have so many HCRI LEDs available, it is an awesome time to be into flashlights.
While I don’t think CRI is the most important factor, it is a significant consideration when I decide what emitter to use in a light (both EDC and otherwise). For example, I don’t care for any of the SST-20 I’ve seen (with the exception of the FD2 I got from Kaidomain) because they’ve all had a pretty nasty green tint. I’d choose a nice rosy 70 CRI XP-L HI over a green SST-20.
Max lumens is not a consideration at all. Most LEDs, even lower powered emitters like 219b, are capable of getting far brighter than I will ever need for my uses. It wasn’t that long ago that an extremely expensive tactical flashlight with an incandescent emitter could do a max of like 80 lumens, and that was mind blowingly bright at the time.
I’d say about 95% of the time, I’m using my lights at 60 lumens or less.
My usual EDC is a Zebralight SC64c with 219b sw35 (thanks Bob McBob). The light I use at work is an Olight S1R II that I modded with XM-L2 3000K 90+ CRI (very rosy!).
My most used lights for my nighttime trail walks are a few D80v2s with 219b of various CCTs. I use L4P LD-A4 drivers set to a max of 2A. At that current, I can run the light at full brightness until the battery is completely flat and it never gets more than warm to the touch. They do about 400 lumens at max output. Nowadays most folks would scoff and say they “need” at least 1000 lumens or it’s useless.
This is what a 219b sw40 looks like in a D80v2 at 2A. Unless you are in need of a super thrower to see several hundred meters (or just want to impress your friends), I just can’t understand why we need to overdrive our lights to the levels that we do.
High CRI would be my preference, but not really important to me. For EDC use, what’s important to me boils down to size of the light, UI, driver efficiency, and temperature control. I haven’t really found anything better than my SC600 MK3 HI for that. 80+ CRI with a neutral duv comes pretty close to a 90 CRI light. If Zebralight arises from their graves and makes an SC600 with new XHP50.3 HIs with 90+ CRI options, I’d be the first to get one.
There are other elements asides from CRI that I prefer as well. I don’t like domed LEDs in reflectors, because they exaggerate tint shift within the beam itself. The ol warmer and greener corona and cooler and pinky-er spill is always gross to look at. Domeless emitter help mitigate that. Certain optics can help mitigate that as well. Speaking of beam profiles, I’d prefer a large and diffused hotspot, minimal corona, and a soft spill. I absolutely loved the way SST20s looked in the original ROT66. I wish I could find a light with that beam profile for EDC usage.
Have you checked out the EO2II with the 4000k SST20? I think it has a wonderful profile that is perfect for EDC usage. Same emitter in the TS21 and that is also a nice beam profile although I prefer the EO2II as the hot spot is more diffused. Both very nice lights and high CRI. One has outstanding run time and the other has outstanding utility.
CRI is down the list of qualifiers when I consider a light. I think color temp is most important followed by tint (and where that tint falls on the line can vary for me depending on temperature/temperature at desired currents). Beam comes next. If I can get that in a high-CRI emitter that’s just icing on the cake. Since we mostly have very decent CRI emitters for sale these days, it’s pretty rare to see a low-CRI, but yeah, avoid those (call it below 75 or 70 depending on the metric). There are few cases for me where high CRI is really so useful as to make it a requirement, and having cut my teeth on dim yellow crappy lights and then on dim crappy led lights, almost anything these days is great by comparison.
I appreciate high-CRI much more in indoor room lighting where you can feel as well as see that difference if you spend much time in it. Flashlight beams are mostly utility for me and most of the time anything will work well enough even if color rendition isn’t stellar.
I think the poll was poorly worded as most polls are. Yes, if given a choice of high cri on almost all lights out there I would almost always choose high Cri. As time goes by more manufacturers are offering more cct and Cri choices. It’s not happening fast enough as far as I’m concerned. Some lights are near impossible to change an LED on so that’s not always an option. And most people are not set up to do that.
Yup, there are many important factors when it comes to choosing an LED in a light. I typically go in the following order:
Color Temperature - The first thing I do is check to see if the color temperature is adequate. Typically I want 4000K to 5000K. If it’s too cold or warm, the other stats don’t matter. I’m not interested unless I can mod it to swap in an LED in my color-temperature range.
Lumens and Intensity - both together determine how much light appears on target. It doesn’t matter how good the CRI is if the LED doesn’t actually light up what I want to see to my satisfaction. In small EDC lights, Nichia 219B fails this test for me. As a result, I currently only have one light with that LED installed (ROT66, which makes up for the low output by having nine Nichia 219B installed).
CRI - I find it’s easier and more pleasant looking at things with high CRI with high R9. This is why most of the lights I’m currently using are equipped with SST-20. I’m willing to accept a loss of 1/3 to 1/2 of the maximum output and intensity on target in order to get high CRI in my EDC.
Tint - Rosy is better than green. And a very green tint may override better CRI. That said, I will accept some slight greenish tint in order to have better CRI. I used to prefer rosy-tinted XPL-HI 5D, but now my preferences have evolved to prefer SST-20, most of which are more green (FD2 bin being the exception). However, I prefer even the greenish SST-20 bins to XPL-HI nowadays. The low-CRI with low R9 just makes things look a bit flat.
The more my flashlight looks like an actual fire, the happier I am with it.
However, when walking around dog crap, or traveling by foot, I prioritize CRI over lumens. If I want to see something far away without regard to CRI, I use a LEP. For the size, weight, battery consumption etc, a LEP beats anything else that’s easily portable by such an overwhelming margin that I see no reason to buy most other throwers anymore.
For close range = High CRI
For medium range = w1’s or w2’s
For long range = LEP
I’m still waiting on Simon to put b35am’s in more hosts though. That may be my new go-to for mid-range.
