EDIT: IGNORE THIS POST. I found out the problem was something stupid that I did and nothing to do with the VPN. On the same day I added the VPN I change a bunch of passwords. I did so on the NAS, but didn’t realize I had to do so inside each networked PC (someone else originally set this up for me). I am leaving the information below because otherwise many comments in this thread wont make sens.
———————————————————————————-Original incorrect comment below———————————————
I tried loading the VPN to my devices. When I loaded it to a PC my internet speed did not seem highly effected so I was encouraged. However I later found out it completely destroyed my network connection! Now when I try to access ANY information stored on the NAS like my pictures, videos etc or open any shortcuts with data stored on it I get an error message about the short cut. If I try to open file explorer it stalls out for a long time and then the screen crashes. Either goes either blue or black. Start up is very slow. Whats worse, I tried uninstalling it and restarting everything but the damage is permanent. Worse still I never setup system restore on this PC so now I will have to reformat the hard drive.
I really don’t understand why this happened. The only theory I have is that because both my internet and the NAS data come in on an Ethernet cable that the VPN doesn’t understand the difference??
When you install a system-wide VPN client, you’re telling the VPN client to route all network traffic from that system through your VPN providers servers. The result of that is local connections are disabled, unless they’re available from the Internet, since everything goes straight to ExpressVPN outside your network.
You still haven’t said what you’re trying to accomplish by using a VPN, so that makes it difficult to give specific suggestions. But, maybe the browser extension is what you’re looking for. That will allow your web browsing to go through the VPN, but gives you more control (you can easily turn it off, or use multiple browsers with different settings, etc.). That won’t affect file shares, since that’s independent of your web browser.
That really shouldn’t happen. If you uninstalled the ExpressVPN software, you should have access to local resources again. Have you checked The Windows Network configuration? It’s possible that ExpressVPN configured a VPN protocol that’s built-in to Windows, and that’s still running. I don’t use Windows or ExpressVPN, so that’s just a guess, but I know Windows has some native VPN support.
You may have to look at the vpn app (assuming you’re using one) for a setting to allow local network (LAN) access, or “network lock” or something. If you’re just using a windows VPN I think it’s buried somewhere in the TCPIP or IPV4 settings and called “use default gateway on remote network” or something like that.
No, I think terminology is getting mixed up here. “System-wide” in this case would mean “Computer-wide”, where installing a VPN on your “Computer”, (also called a “Computer System”) affects everything that computer tries to access.
Other things on your network, apart from that particular computer (system), would not be affected by the VPN, like a NAS, or a chromecast, however the computer with the VPN (if active) would not be able to talk to them. Other computers on the network (like your shop one) would be able to.
Rebooting all the equipment probably introduced some other unknown problem that has nothing to do with the VPN.
Can you uninstall the VPN? At least until everything goes back to normal.
VPNs can introduce slowness. There’s not much to be done about that.
For one, they are encrypting everything, and the more encryption there is, the more horsepower that takes, which can slow stuff down.
For two, a VPN is routing all your traffic somewhere first, before it goes wherever you say you want to go. Like if you decided it would be a good idea to use a VPN that makes you look like you’re in Luxemborg. Guess what, just opening a page to Google has to route through Luxemborg first. Playing CoD or something is just crazy talk at this point.
For three, you’re depending on their servers (in Luxemborg in that example) for speedy routing. Picture a freeway interchange. It’s like that. The bigger the better. How big is theirs?
azj. Thanks for joining the conversation, and clarifying system wide. I already uninstalled the VPN. The problems with house PC continued, and after the restart of all my systems including the NAS the shop PC started having the issue. I don’t think its a coincidence that right after I installed the VPN all of this happened. I have never had any of this happen before.
How did you “go to network status”? Was that on the NAS, or a PC?
It’s highly unlikely that the VPN client on one of your computers modified your NAS.
Unless you’ve had that working before, I wouldn’t expect it to (i.e. it’s not a very good test). In general, you can’t just connect two computers, and your NAS is likely just a small linux or bsd computer, with a straight-through network cable. Unless one or the other has an auto-configuring network adapter (which used to be quite rare, and I think still is), you need a crossover cable to do that.
ETA: Plus addressing issues. That’s just very unlikely to work.
There are 2 things to check. If the network status on the PC is “not connected” there is either a physical problem with the NIC in the PC, the cable, or the switch. Or, it can’t connect to the DHCP server on the router to get its assigned IP address. Check the lights on the port on the PC, lights on the ports on the switch, and double-check your router is still working.
Given that you’re seeing multiple problems on your local network (I think), it’s possible your router is disconnected from your LAN, or not functioning. I would focus on one PC that’s plugged directly in to the router, if possible. Get its network connection working properly by checking every step between it and the router. If you can’t get that working, you’ve almost definitely got a router problem.
I think most paid VPNs are pretty much a scam at this point with all the Youtubers shilling for it. For securely accessing your home network, including accessing Synology from afar, I recommend Tailscale. I have been using it for many months and it is great and free. It runs based on Wireguard VPN.
Well, at this point, it sounds like your Synology is not getting proper network settings. I’d try the following:
1) turn off the pc with ExpressVPN on it, just to be sure (this shouldn’t be necessary, but hey, just to be sure)
2) reboot the Synology. This can take 5 minutes or so. To do this you are probably going to have to tap the power button, wait a bit for all its lights to go out, then tap it again. If that doesnt work, hold down its power button until the lights go out (force it off, less desireable), then push it so it comes back on. A much worse/last ditch method is to pull its power.
3) try and ping the Synology after waiting the 5 minutes or so from a different computer. It appears from your screenshots that its name is “nasstorage”, so you’d open a command prompt by typing “cmd”, and either press enter or click the command prompt icon, then in the black command window type “ping nasstorage” (no quotes). You may have to do this a few times. Hopefully you get messages that say “Reply from…” after a bit and not “Request timed out” or something else bad.
You can click the “X” or type exit to get rid of the command window.
If that doesn’t work then I’m not sure what’s up with the Synology, but it really shouldn’t have anything to do with the VPN. Maybe unplug/replug/check its network cable.
If all that does work, then turn your VPN computer back on and go from there.
Good luck
As far as one vpn service over another, ExpressVPN is fine. I happen to have “Private Internet Access”, but only because I got a good deal many years ago and I knew how to connect to them using a router. I also connect to them using a PC when I’m at work with no issue.
They throttle the speed of the free accounts, and don't allow file sharing.
Also, with a free VPN, you are the product, which means they sell your data, which is the exact opposite of what you want with a VPN.
If you care about your privacy, do not get a free VPN.
"If you really want better protection online, avoid free VPNs. While you might save a few dollars each month, the risks to your privacy and data are not worth it. In fact, using a free VPN could cost you a lot more than the subscription to a premium provider."
I don’t know about file sharing and the speed does slow from some free locations but Proton was one of the best for protecting your info. It is fast enough for me but I don’t use it for gaming or anything requiring a lot of speed. At least it was rated highly when I joined up over a year ago.
