More New Cree Goodness coming....
The XHP70.3 Hi looks like perfect LED for ZL SC700d :sunglasses:
XHP50.3 HI 4500K 90CRI from mouser with a beaded TIR :
0.1A
CCT = 4312K (Duv 0.0045)
Color Rendering Index (Ra) = 92.2 [ R9 = 69.3 ]
R1 = 91.6 R2 = 94.2 R3 = 95.7 R4 = 91.0 R5 = 90.1 R6 = 90.5 R7 = 96.2
R8 = 88.5 R9 = 69.3 R10 = 85.5 R11 = 90.0 R12 = 67.0 R13 = 92.0 R14 = 97.6
IES TM-30-15 Rf = 88.76 Rg = 96.79
0.5A
CCT = 4440K (Duv 0.0042)
Color Rendering Index (Ra) = 91.4 [ R9 = 65.8 ]
R1 = 90.6 R2 = 93.1 R3 = 94.4 R4 = 90.8 R5 = 89.4 R6 = 89.0 R7 = 96.2
R8 = 87.7 R9 = 65.8 R10 = 83.0 R11 = 89.5 R12 = 67.0 R13 = 90.9 R14 = 97.1
IES TM-30-15 Rf = 88.94 Rg = 97.42
1A
CCT = 4524K (Duv 0.0034)
Color Rendering Index (Ra) = 90.8 [ R9 = 63.4 ]
R1 = 90.1 R2 = 92.4 R3 = 93.5 R4 = 90.7 R5 = 89.1 R6 = 88.2 R7 = 95.6
R8 = 87.1 R9 = 63.4 R10 = 81.4 R11 = 89.3 R12 = 67.9 R13 = 90.3 R14 = 96.7
IES TM-30-15 Rf = 89.00 Rg = 97.93
2A
CCT = 4586K (Duv 0.0033)
Color Rendering Index (Ra) = 89.7 [ R9 = 58.9 ]
R1 = 88.9 R2 = 91.1 R3 = 92.2 R4 = 90.1 R5 = 88.2 R6 = 86.8 R7 = 94.7
R8 = 85.7 R9 = 58.9 R10 = 78.6 R11 = 88.7 R12 = 68.4 R13 = 89.0 R14 = 96.0
IES TM-30-15 Rf = 88.72 Rg = 98.43
I didn’t test higher because it’s a quick test without heatsink, anyway the tint is sunlike (0.0033), or slightly greener at lower current. Disappointing that it’s not closer to the BBL
The beam looks quite good even with SMO reflectors.
At 0.1A with KR1 SMO reflector :
spot : CCT = 4605K (Duv 0.0033)
Corona : CCT = 4191K (Duv 0.0067)
spill : CCT = 4383K (Duv 0.0032)
:+1: for the data thefreeman. Cree is not the new Nichia but it looks decent, 90CRI Cree’s that I have seen before were awfully green (that was before I had a spectrometer, so I can not back that up with duv numbers), this sounds better.
Added a quick spot, corona, spill measurement with SMO reflector
A bunch of them got added in order, availability announced for March.
Cutter has some stock of 3V XHP50.3 in 3B chromaticity.
The 4000K 80+ CRI looks interesting. But man, $12 a pop
I have these underway, any interest
XHP70D-H0-0000-0D0BP250E 20pcs stock
XHP70D-H0-0000-0D0BN450E 200pcs stock
XHP70D-H0-0000-0D0BN445E 10pcs stock
XHP70D-H0-0000-0D00P20DT 20pcs stock
XHP70D-H0-0000-0D00P20E1 20pcs stock
XHP70D-H0-0000-0D00P20E2 100pcs stock
cheers
For those who love warm XHP50.3 HI 3000K, XHP70.3 4000K 90CRI
available here
Too bad we don’t know what the tint is like. If we know for sure it has rosy good tint, I would buy.
Have you ordered from this site before? They mention shipping to Russia & Ukraine, do you know if they ship to EU/UK?
Do I try a 70.3 in my FET L6?
Maybe I’m not so good at reflowing, but these XHP50.3 HI 4500K 90CRI LEDs seem to be rather fragile when it comes to current. I went just above the limit on two of them at 12V and they burned out rather quickly. My heat sinking was probably not adequate either but for now I I’ll give up on these until someone who knows what they are doing does a more thorough test.
I got a 6v XHP50.3 HI doing 4k lumens I think the current draw is like 8-9 amps it’s okay but I’ve only used it for testing. I tried to reflow one and the dome melted.
Must be my crappy reflowing… I should stop buying bare LEDs and only get mounted to MCPCBs by people who know what they are doing.
I re-configured my driver for 6V and put in a MT-G2 instead, those things take a lot of abuse.
Soldering the XHP70.3 LED on a copper substrate DTP.
I can check with a spectrophotometer. If you are interested.
Svitlo, are you the owner of Beriledz? :)
Always fun to see someone else’s reflows and tricks, thanks for making the video. :+1: :slight_smile:
A spectrometer test would be nice, I always prefer (also) a measurement with a reflector on the led and measuring in the hotspot of the beam.
Colorimetry results would be welcomed indeed, and like Djozz said, a real world measurement is preferable, especially not a bare LED measurement with the device right above it.
Something like a spot/corona/spill measurement with a reflector like this doesn’t take too long to do and is quite informative about the LED.
