Aside from the anodizing being different shades (black vs charcoal) and a few internal differences (drivers & emitter isolators), these two lights almost look like they came from the same factory. I prefer the Beamtech BT-950L for the slightly longer threads and better driver. Other than that it's a toss up.
The larger hotspot of the BT-950 is, I believe, due to two things. The first being that it's driven at nearly twice the amps of the Keygos KE-5. Second is the isolator on the Beamtech BT-950L keeps the reflector from sitting as low as the reflector in the Keygos. This could always be changed if it bothered you.
Hope you enjoyed the show! I'll be here all week. Don't forget to tip your server. ;)
Sashi, I suppose that pic is a bit deceiving. The Keygos was a stock KE-5 sent to me for a driver replacement. The pic was taken with it’s stock driver in high which only pulled 1.6A at the tail. The BT-950L was literally twice as bright and the sheer amount of light coming form it makes the beam focus seem a whole lot different than the Keygos.
Here is a pic with the white balance turned down way low to show the hotspots better. Mind you the BT-950L is still putting out at 3.26A in this pic compared to the 1.62 of the KE-5
Very good review, thanks. For more pics, see this old deleted ForSale listing by Blinders https://budgetlightforum.com/t/-/8270 (LINK). As Blinders and I both pointed out, there is an intermittent issue with this light where it may not turn on after you reassemble it, probably due to a short somewhere or inside the pill when it is pressed by the battery. I had to reassemble mine 5 times for it go come back on. JonnyMac, in your pics, you can see the white led spacer has a dark ring showing exactly where the reflector presses down. That ring also overlaps the red and black wires and solder points, so maybe there's a short there too. Just guessing, since i still don't know how the grounding works.
As for the different beam pattern from the KE-5, maybe it's just due to how far the LED emitter goes into the reflector, and a simple piece of paper or electric tape can change the distance, let alone a thick white nylon led protector. Again, just guessing.
Thanks for the detailed pics. Oh, maybe you got better packaging because you're one of their special friends (re: group buy etc).:) Mine came all banged up as usual, and didn't even have the bubble wrap inside the white box... geez it's not like some bubble wrap is going to add any weight or anything to their minimalist envelope. /rant :)
Thank you for the nice review and the good pictures. I love the idea of your Mac-lanyard and will copy the idea for 1-2 flashlights - hope you will not sue me for this
I have two Keygos KE-5 - one has the same driver (East-092B), the other the East-092 (do not find any difference between them).
Happy to share the lanyard attachment idea. Have at it! Just feed the para cord through the hole, clip a clean end on it, heat it to melt the cut then flatten with your finger to make a flange that won’t pull through the hole. No unsightly knot to deal with and it won’t come out unless you cut it out.
You got the good Keygos then. It’s just such a lottery with them that it’s nice to find an alternative like the BT-950L
Thank you for the review and all the pictures JohnnyMac. Seems like a fair price for those in US with the fast shipping and all.
I just wish that it did not look like it was painted black. YMMV
Louis from Tmart contacted me after seeing the review and has offered to do a group buy on the BT-950L. Just $22 with free shipping from the US. Great deal they are making for us!! Thanks, Louis!
Thanks for a great review, JohnnyMac! You are killing my wallet. I've been thinking about getting a Keygos but was put off by the inconsistency. This looks like a killer deal with the Tmart discount.
