Nichia 519A
27 posts / 0 new
Agro
Agro's picture
Last seen: 19 hours 28 min ago
Nichia 519A
A new LED from Nichia:
http://www.nichia.co.jp/en/product/led_product_data.html?type=%27NVSW519...
Highlights:
  • 3535 footprint
  • Thermal resistance of 2 K/W (very good)
  • 2.2A datasheet max (not so good)
  • CRI up to 8000min
Lightbringer
Lightbringer's picture
Last seen: 7 min 13 sec ago
8000 cri? Excellent! That’s like 80× better’n sunlight!
I’ll take 10…
Hmm, looked at the datasheet… where ya see the cri value?
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 1 day 2 hours ago
Robin Dobbie wrote:
So will the thermal resistance being half of the 219C likely mean noticeably longer turbo?
“Thermal resistance” is how much heat the LED chip itself can “resist”. That means it will likely endure higher currents and there is less worry of frying it compared to the 219C, 219B, etc. It’s not a rating of heat produced by the LED.
MtnDon
MtnDon's picture
Last seen: 5 hours 51 min ago
Download the pdf spec sheet from the download section of the posted datasheet link for CRI and color temp and other specs….. or click here
BurningPlayd0h
Robin Dobbie wrote:
I thought it just meant how well the substrate conducted heat away from the die. The max temp appears to be the same as previous generations.
That could be, I just know the result is is how much you have to worry about temp at the emitter and/or junction. If the actual transfer of the heat is what is improved that wouldn’t lead to longer turbo times though, since the temp sensors in every light aren’t located right next to the emitter itself and transferring it into the board and head of the light slightly faster isn’t going to change that fact that you’re creating a TON of thermal energy very quickly.
Agro
Agro's picture
Robin Dobbie wrote:
I’m guessing the extra 0s mean they’re not making any promises on R9. According to some website: “Ra is just a symbol in the formulae for general CRI calculations, but has become widely used as a synonym for general CRI.”
Mostly.
Like 9080min which means a minimum CRI 90 with minimum R9 80, this means minimum CRI 80 with minimum R9 0. Note that CRI can get below 0, so “minimum 0” is actually some (though very weak) upgrade over regular CRI80min spscs.
AEDe
AEDe's picture
Last seen: 2 hours 15 min ago
Agro wrote:
Mostly.
r9 min 00 means usually r9~20-30. is cri min 80 means cri~85 it is way better that leds without cri rating, as old xml2 wich is still widely used.(cri 65-75 and r9~-30)
mbp
Last seen: 13 hours 18 min ago
Not sure this does anything for me at 80CRI given how close performance is to LH351D 90CRI. 450ish lumens at 1A for this compared to 400ish for LH351D, lower rated max, other specs comparable. Probably a pass unless tint is really nice.
Scallywag
Scallywag's picture
Last seen: 3 hours 9 min ago
Nichia, for me, has been hit or miss on tints. Good uniformity, but my 5000K 90CRI 219Cs were the greenest LED I’ve dealt with.
Will be interesting to see how this does above spec. I’m more excited about the Lumileds Luxeon HL2X
Agro
Agro's picture
Looks like Eurekatronix is going to carry these:
https://www.eurekatronix.com/product-page/nichia-519a
icpart
Last seen: 11 hours 9 min ago
I found that LED in Convoy store in stock
https://www.aliexpress.com/item/1005003779476947.html?spm=a2g0o.store_pc...
Any additional info compared to another 3535 leds?
I found interesting info over reddit
https://www.reddit.com/r/flashlight/comments/rmzqe9/ned_armytek_wizard_c...
jon_slider
jon_slider's picture
Last seen: 8 hours 31 min ago
thanks for the link..
my understanding, from reading only:
the 519 LED is larger than 219b, and not as pink as sw45k
519 has a larger hotspot and makes more total lumens than 219b.. similar to xp-l and LH351d, but with higher R9 CRI and more rosy tint
maxchaos92
Last seen: 3 hours 6 min ago
Can someone link a guide or discussion about CRI and RA? I’ve discovered today that 9080 isn’t the led name but the color rendering, now want to delve deeper Crown
Maximilian Garage Flashlight Review & DIY https://youtube.com/channel/UC2MCNSaJeOoB6CM1WKc4v1g
jon_slider
MoreHiCRILumens
MoreHiCRILumens's picture
Last seen: 8 hours 25 min ago
So are you guys saying this Nichia can replace LH351D’s?
If that is the case then SP36 BLF could get led swap soon even though opening takes a little bit more work.
Waiting beamshots. Cool
QReciprocity42
Last seen: 2 hours 18 min ago
MoreHiCRILumens wrote:
So are you guys saying this Nichia can replace LH351D's?
The 519A has slightly smaller die size and higher R9 compared to LH351D, so I would expect the output+peak current to be somewhat less. But I would welcome a nice surprise if future testing indicates otherwise!
JaredM
JaredM's picture
Last seen: 2 hours 3 min ago
Ordering a few. Will test for sure
https://fundrazr.com/osturaband
No affiliation, just a fan.
jon_slider
Ordered
Resistance was Futile..
snyder.c
Last seen: 8 hours 26 min ago
Curious to know the max current these can take. Wondering if need to pair one with a 3A, 5A or 6A driver. Thanks for testing guys!
Yokiamy
Yokiamy's picture
Last seen: 42 min 12 sec ago
The 219B datasheet says :
Forward Current IF 1500 mA
Pulse Forward Current IFP 2000 mA
So this one must be a bit better, since it can handle more current. (since when did we stay within datasheet specs?)
QReciprocity42
My 90CRI 219C's have no issues with the 5A driver, unless efficiency is a concern. The 519A has around double the 219C die size and should have no issues with 5A. Unless there are some unexpected abnormalities like with the 219F, where the glass dome cracked at 4A.
MoreHiCRILumens
Not an issue. Just would like to get something a bit warmer to SP36 vs. 5000k LH351D’s. 4000k is a bit too warm so 4500k would be perfect. Also could throw a bit better even though that is not an issue either because I mainly use SP36 with diffuser as a table lamp etc.
merlot
Last seen: 9 hours 44 min ago
I’m very keen to see the output of these, especially the lower CCTs. Do we know if anyone is planning on testing them?
jon_slider
Pöbel
Pöbel's picture
Last seen: 2 hours 31 min ago
thanks for the test. Ordered some.
Will replace the LH351D Hi CRI in my OG Armytek Wizard (the first Version) Smile
NeutralFan
NeutralFan's picture
Last seen: 4 hours 4 min ago
Just ordered 3 of them to replace the 4500K 219Bs that I got from KD: Kaidomain has 219B 4500K 92cri in stock
Although the KD 219B 4500Ks are good, I’m not that impressed whenever I use the flashlight compared to my other 4500K flashlights. I guess I need a little rosiness in my tint. And I should’ve know better since the KD LEDs have a D240 flux bin which is pretty high. Good for lumens, but not good for tint.
I’d rather use my flashlight around the house than turn on the lights.
Kakapo
Last seen: 4 hours 49 min ago
I’m very interested in this emitter, hoping to hear more soon on it!
