【Wurkkos News】New arrival Wurkkos TD01 1000 meters long throw 21700 Tactical Light
yes, we also didn’t expect red with the camo too, The oxidation factory played a joke on us
Sorry, we afraid we have to delayed 3-5 days because of near the spring festival holiday of China, many workers leave early so Assembly efficiency becomes lower :cry:
a power green light throwing?
I suppose that the camouflage effect is the reason for the higher scrap rate of the blue/pink version? In that case, a plain blue version would be nice, or any of the other existing solid colors, as long as there’s an option besides Boring Black.
But what I’d love more is a version with the rubber switch, like the picture of the prototype that was posted. :smiling_imp:
Glad to see Sofirn had adopted silicone diffusers, which I suggested to Barry. They’re more flexible and tolerant of small size differences, and have a better retention grip than rigid plastic ones.
In addition to anodization, has Cerakote been considered as an option?
May be this is your chance to swap the resistor to fix the parasite drain? Or it is already done?
Orange, Zombie Green, Purple
I already have TS21 in Grey, Red, Green Camo, Blue Camo OTW / Purple FC11 and Green HD20
Can I get an FC11 code for amazon UK please?
I’d also like to see Wurkkos make an attempt at the Stormtrooper-esque white finish with black trim like Olight is doing. Not sure how practical, or costly, it is, but it does go beyond the standard black, and other anodized colors.
here is 20% code —W8WAY55Y valid in 6 hours
FC12 code for Amazon.de now—ZQRHEMA4 20%
Ts21 code for Amazon US please.
Can I get a TS21 Metal Gray code for US Amazon?
Thanks!
wurkkos.com last deal before Chinese New Year Holiday, models will FC12, WK30, WK01, WK02, TS30
You’re very right. After you posted the weights I decided to get a Sofirn HS05 specifically for a backup headlamp. And then I purchased a Nite Ize Lite Holster Stretch with rotating clip for the HD20. One can easily rotate the clip 180 degrees to force the light upright—and flush/snug—against a backpack strap (without sliding down).
The holster fits the IF22A and my IF25A, too. I always wondered if this holster would comfortably stretch to accommodate the two IF lights I own and it does. It is a better fit-for-purpose design than the lashing-to-a-pack-strap-with-paracord idea I had in case the HD20 was too heavy for prolonged head wear. I am curious to see if a HD20 shortie will securely fit into the stretch holster without popping out the top (with the head still able to fully clear the top of the holster).
I guess I’ll see. The shorter Wurrkos tube order is still en route.
Holster image from the Nite Ize site (clickable for a Nite Ize store re-route):
May I have a code for Metal Gray 5000k on Amazon us?
Thanks
yes try —FSY7-ABX7ZW-NEMUAG
TS21 white and orange diffser available
