google-translated OCR of the images:
High-energy wick, soft and staple
Intelligent temperature control to protect the body
Adopt high-efficiency stable drive circuit (dual high-power MOS) when the voltage/temperature exceeds 55°C
The preset value automatically activates the temperature control and will kick down the gear
Integrated battery compartment
The battery compartment is integrated with the barrel, and three 21700 lithium batteries need to be installed to use it. This product itself does not have batteries, and the customer needs to provide batteries by himself.
positioning hole
dowel pin
Note: When loading the battery, the positioning pin of the tail cover should be inserted into the positioning hole on the end face of the battery compartment and then tightened.
Power display at a glance
Button with independent power display and fast charging prompt, keep track of system power status
Fast charge indicator:
Fulfillment:
Charge:
Steady red light
green light flashing
Green light is always on
full:
Slow charge indicator:
Fulfillment:
Charge:
Red light goes out
full:
MATEMINCO
MT-18X
Outdoor training mecha flashlight
Advanced sub-light board design, color changes with voltage, intuitive estimation of battery voltage status, high-efficiency direct drive
IPX7 waterproof
USB two-way fast charging
Over temperature protection
super bright long shot
Made for enthusiasts!
Support various mobile phone emergency charging
Emergency Charging Say Goodbye to Power Outages
When going out outdoors, when the mobile phone has no power, it can be used for emergency charging.
Fast charge and discharge; fast charge red light on, green light dims as the power decreases; burst charge and discharge; red charge light off, green light dims as the power decreases
Alloy quality, sturdy and durable
Rock quality, drop resistance and pressure resistance
Made of high-strength aluminum alloy material, oxidation treatment is effective for anti-drop and compression, prolonging service life
21000 lumens
Enough for outdoor night activities
The longest range is up to 871 meters, the night has no end, and it can be used for mountain climbing
Search and rescue, camping and other night activities
Stepless dimming
A step in the hands of the hospital
in place
·With gear memory function
Professional waterproof
IPX-7 waterproof
IPX-7 strength waterproof design, can eliminate the harmful effects of water jets on all sides to resist outdoor accidents
Fully sealed structure
High density waterproof ring
Micron-scale processing
One-handed operation, free adjustment
Control with one hand, adjust at will
You can adjust the brightness of the 4 colors of sub-light LEDs by tightening and loosening 4 adjustable resistors, but you need to unscrew the head cover and lens, and the customer decides by himself.
Secondary light color change:
3.9v-4.2v, green below 2.9, below protection, all auxiliary lights are turned off
, pink, blue 3.3v-3.9v
pink,
blue
2.90-3.3v
Red
