Agree it’s on the heavy side. It has 6 21700 cells in it, just weighed mine and it came in at 520gm or 1.15lbs. I think the Li polymer type cells are probably more weight/size efficient, however, I don’t think your going to find one much under 500gm that actually delivers 26800mAh!
From the volume and the weight, I would have guessed it should be able to recharge iPhone 13 pro zillion times; I mean the actual battery inside iPhone must be only 1/20th of this beast of the battery pack alas, it only claims to do 3x for iPhone. Is Apple (or cellphone makers) that much ahead of the battery pack industry?
I bought 6 from Techdirectclub back when they were selling them in lots of 3 for $11.99 shipped. I checked a few months ago and they longer have them in such small quantities.
The ones I got all measured at around 4800 mAH on my Opus 3100.
These cells come close to a 40T —- The 40Ts put out a little more at full charge (fet driver light ) The crazy part is — The Tesla cells put out more than the 40T from 3.95v- 3.45v
I’m tempted but there aren’t any reviews for this light. Does Nextorch make decent flashlights? Anyone received this light and care to share your opinion? Does anyone know what kind of driver it comes with?
I just received mine. Very well made. Always starts on high. Lightly press on the switch to go lower. It gets warm immediately, good heat sinking.
In my opinion, a good deal.
Thank you guys! I really considered this but I'm about to install an xhp50, 5K in an S21A with a TIR, that I've had in a Convoy L2. The 'dark' hole is getting to me and the MTN FET driver is too much with two hi drain 26650s.
And to make the hole in your wallet bigger, this looks good: https://www.myvipon.com/product/8694324-HARDELL-Digital-Caliper-Micrometer-Calipers-Measuring-amazon-coupons?sl=dea061f648486e897590a6914df31e8d&f=deal
Yeh, when it’s delivered by an Amavan, they do that. (Tracking number “TBA123456”, etc.)
Even keweler, it you know it’s “out for delivery”, and can catch it just before, you (if done in your area) can also see a map and doodad to mark where the Amavan is. If lots of deliveries in your area, also a blurb like “3 stops before you” or however it’s worded.
