Sofirn c8f head is larger than d4s. I already have a c8 with 90.2, which is what I carry when I have a jacket. And I have a kr1 with 90.2, which is very similiar to what I’m asking in this thread. I guess I’m being very specific at the moment haha. Needs 4x emitter 39mm head size.
Skylumen sells a version with dedomed emitters for more throw which should match or surpass most configurations of the D4SV2 (based on his numbers at least).
That light loses lumens ridiculously fast. If you want a small 21700 sbt 90.2 get a manker u22 iii 90.2. No anduril though.
It is weakish and green tinted on low power but throwy and nicely white on turbo without need for a green filter (ymmv). Easily out-throws my w2 d4sv2. Also eats batteries, gets super-hot quickly, but small and goes 900m. I carry one, it’s nice, although I feel LEP’s make it almost obsolete (again, ymmv).
I’d suggest getting the sft-40 or osram version though, as the sbt 90.2 really needs a bigger host and more batteries to fully shine, but it’s a much better light than the lumintop.
I like the Wildtrail WT3M SST40 very much. It has replaced my previous favourite D4S.
21700 Support and charging port are great improvements.
I’ve ordered a second one. Want to reflow SST40 emitters to SFT40 for getting more throw.
Size comparison: EA01,D4S, WT3M, EC01
I don’t know anything about it, but the Wurkkos ts30s is a smallish anduril sbt 90.2 that you may find interesting. Has good reviews, and looks like it holds lumens decently, considering.
There’s also the Acebeam L19 (no anduril). Pricey but probably worth it. I may pick one up sometime.
This has been my one and only complaint about this light. 26650 quality cells are going to get difficult to find and 26800’s are not a serious option due to lack of production. For some reason, Hank does not seem to want to make a 21700 tube for it.
I like this little light a lot, too…wasn’t sure at first but it really grew on me. I’ve pondered swapping for SFT40 as well but I’m not sure what the beam will look like with that shallow reflector (i.e. whether the beam will still blend into a decent tighter one or end up with three distinct-ish visible beams). One way to find out I guess…
If you feel the stock KR1 is still not throwy enough for you then do not get the DT8, it’s only as throwy as a KR4. I have one in W2 which is quite throwy for an EDC TIR light but I’d guess its nowhere near the reflector KR1.
It’s really interesting to see different preferences and demands for an EDC light from different people. For me even the stock quad TIR is too throwy…
My d4sv2 is a skylumen version. Manker u22 is a nice light but doesn’t meet my requirement. Head is too large. Wild trail is a contender , but I doubt it will have more throw than my d4s due to the orange peel and shallow reflectors. I also have the wurkkos ts30s, not bad of a light but Head is too big.
But good news, Vinh over at skylumen was able to put the optics from the d4s into a lumintop fw21 pro. So now I have my 21700 and exact same size head diameter and my quad emitters. And better yet, and tail switch. Now I just need to decide what emitters I want in there. I want the most throw without sacrificing too much lumens. Was thinking w2’s would be the best, but w1’s is another option. Just not sure how much more throw I can get out of the w1 vs w2 and is it worth the Lumen loss.
I apologize I said the c8 was 39 mm but I think that's the size of the lens a c8 is like 44mm
sorry for the confusion
Out of those, I would go with W2 unless you want pure throw. You could ask about SFT40 as well. That would be a monster of a light.
Edit: Now I kind of want one of these. I prefer a tail switch and this custom mod sounds incredible.
No worries. I did the LED swap today. The beam will get much tighter. Ive measured ~ 70 kLux (instead of ~42) at startup with full charged Samsung 40T.
heater, good news…that’s great and thanks for doing it and sharing the results! I think I’ll pick up a second one just for this mod.
Sofirn IF25 or IF25 with tint ramping.
It has usb-C and 21700
An sbt 90.2 is simply the wrong emitter for a primary edc light for 99% of people. There are too many compromises that have to be made. Once we start talking about a jacket-pocket sized light it becomes more doable, but still not ideal.
I meant to suggest this the other day and forgot. It is a decent option.
The Fireflies E07x Pro has an upgraded narrow optic. Jack, the owner of FF, said that was the throwiest optic he could find and it throws MUCH better than the previous E07 optic. Too bad it is sold out on his website.
Sofirn if25 does seem like a nice light to have but it’s not gonna work. Seems to be in between a d4 and d4s. So head is too small. And thanks for doin the mod to sft40, now we know the throw measurements.
Looks to me, the d4s with w2’s is supreme. I’m curious about the e07 pro though. Did not know it has new narrow throw optics. I wonder what lux would 7x w2’s in the eo7 pro do.
The original e07 does about 50kcd with w2’s. The new pro optics probably be 75kcd if that.
My d4svn does 100kcd.
As far as I’m aware you can’t buy one anywhere (except maybe used) so it isn’t actually an option, and no one knows when they’ll be available again. This is leaving out the multitude of QC complaints popping up about FF.
So from that perspective, it seems you may have looped back to Hanklights.
I like the Imalent R30.
9k lumens and 500 meters throw. 21700 and NO Anduril.
Only perennial problem with Imalent is they don’t make the switch
easy to find. Not even in daylight.
Cheers.
Recieved my custom quad w2’s lumintop fw21 pro from skylumen today. It’s one beast of a light! It’s brighter than my d4svn with the same quad w2’s and throws 40% better as well!
And I’m only using a 40t. I’m using red Vapcell on the d4svn. This new light has now dethroned my kr1vn with sbt90.2. Similiar brightness but the fw21vn throws 40% better than the kr1vn as well. So happy with my new light.
Edit: well I’m not sure if it equates to 40% more throw actually. But the lux number is 40% higher. I measured both the kr1vn and d4svn at 85lux. And I got 128 lux with the new fw21vn. These numbers are not a rating test. I just put my lux meter on a chair and walked about 25 feet away. It’s just a test for me to compare these three lights, not true lux numbers
