Overview: All Eneloop batteries 2005-2022 (Finally a new Eneloop, June 2022)
868 posts / 0 new
how2
Pete7874 wrote:
Ventsi wrote:
Does anybody know what happened to Nkon.nl ? I can’t open their website for a few weeks now.
https://www.nkon.nl/ is working fine for me. Do you have some privacy add-on in your browser that’s blocking it? Try a different browser and/or device.
Working fine for me as well.
Ventsi
Last seen: 9 hours 41 min ago
Thanks… somehow it works now… same browser and I even clicked the same bookmark. Weird.
arow55
Last seen: 27 min 55 sec ago
How important is the wrapper on eneloop? If starting to wear out is there a chance of short?
ChibiM
ChibiM's picture
Last seen: 11 hours 28 min ago
Wrappers are important on all batteries in my opinion. But it also depends on the application. If it doesn't have metal stuff that can touch the cannister, it shouldn't be too much of a problem.
ghezzano
Last seen: 8 months 1 week ago
Hi everyone, I am trying to recharge my Eneloop batteries with my BC1000 battery charger but a battery is not recognized and the display shows “null” as if the battery was not there. Should I throw the battery away or can I get it back somehow? It’s a “botanic edition” and I’m a little sorry .. thanks in advance.
thefreeman
thefreeman's picture
Last seen: 4 hours 9 min ago
With all your cells or just one ? It does that if the voltage is below 0.9V. if you have another charger you can try to put it in it so that it raises the cell’s voltage above 0.9V (if it doesn’t have this type of protection), then put it in the BC1000. Or you can parallel it with another cell for a short moment, preferably not a fully charged one to not get a too high current.
ghezzano
No, it is not recognized by any cell of my “BC1000”. I will try to use another charger with the voltage you told me. Thanks x now.
flydiver
Last seen: 8 hours 1 min ago
Old style/slow/dumb chargers, the kind that take many hours to charge, are….very…slow/low output, and may never shut off, are worth having around for this. The will attempt to charge anything that will fit. Boost the ‘dead’ battery with one of these for a few minutes, and it will generally be recognized by a good smart charger then. Had to do that to 2 AAA cells from a used home phone system I got yesterday. All batteries being cycled and tested now.
If dumb charger does not work, do the parallel charge with another cell. If THAT does not work, you do have a dead cell.
To Air is Human, to Respire….Divine.
ghezzano
Thanks everyone, I solved and recovered the battery that was not working. I practically put 4 other batteries in charge and as soon as they were ready the battery was finally recognized by the battery charger and it was therefore possible to recharge it.
ChibiM
ChibiM's picture
Nice!!
ChibiM
ChibiM's picture
After so many years, finally a new Eneloop battery.
Besides a new kinds of packaging for the Eneloop Lite and Eneloop PRO, the 5th generation standard Eneloop White has just launched in Europe.
Thanks goes to one of our readers, Daniel.
Minimum 2,000mAh, but same cycle life
hIKARInoob
hIKARInoob's picture
Thanks for the update! You know there are whole bunch of flashlight reviewers these days, but when it comes to Eneloops, you’re the man! Thumbs Up
roostre
Last seen: 1 week 1 day ago
Thanks for the update ChibiM.
Did the capacity of Eneloops improve for the 5th generation standard Eneloop White?
Interesting that the new packaging states "NEW CAPACITY min. 2000 mAh" and "NEW CAPACITY min. 800 mAh" (but there is also a *1 symbol next to the word "min." and I wonder what that means).
For Eneloops I have recently purchased in the USA (I'm not sure which generation they are):
The packaging for AA Eneloops lists "Capacity up to 2000 mAh" and the battery wrap on the AA Eneloops states "min. 1900 mAh":
https://www.amazon.com/gp/product/B00JHKSN5I/ref=ppx_yo_dt_b_search_asin...
The packaging for AAA Eneloops lists "Capacity up to 800 mAh" and the battery wrap on the AAA Eneloops states "min. 750 mAh":
https://www.amazon.com/gp/product/B00JHKSMIG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
How many flashlights does a "real man" need?
None, real men are not afraid of the dark.
MoreHiCRILumens
MoreHiCRILumens's picture
Last seen: 3 hours 32 min ago
I think that *1 means like 1 pcs capacity.
Pip
Last seen: 1 hour 30 min ago
The *1 is probably linked to some fine print on the back of the package, as well as the *2 after recharge up to 2100 times.
ChibiM
ChibiM's picture
In Europe, our Eneloop packaging shows Min. capacity only. This has been the case for many years.
I thought that the US also changed that, but it seems not. So they still show Min. capacity + Typical/Rated capacity.
The new AA will do 2,000mAh instead of 1,900mAh
and the new AAA will do 800mAh instead of 750mAh.
These are only available in Europe.. for the moment.
I just ordered 4 AAs and 4 AAAs.
MoreHiCRILumens
Oh, looks like I need to get new ones too. Nkon?
ChibiM
ChibiM's picture
No, I got them at Amazon.. Nkon will probably have them soon as well.
ChibiM
ChibiM's picture
Here's a quick video:
arow55
Could someone measure the diameter compared to older generation. I have some devices that are a tight fit. Wondering if the extra capacity requires bigger battery.
ChibiM
ChibiM's picture
Unfortunately, I have a cheap digital caliper, and it's not so precise in the tens/hundreds of millimeters.
1st gen 14.11
3rd gen 14.13
4th gen 14.13
5th gen 14.16
These measurements aren't static... Each time I measure, they change slightly in the tens/hundreds, and sometimes go up to 14.20mm.
But every time I measure them, the 1st gen has the lowest number, and 5th has the highest number
JenkinsMatti
Last seen: 18 hours 41 min ago
Thank you for the heads up & the video ChibiMBeer
arow55
Thanks much for measurements.
agungz
Last seen: 3 weeks 3 days ago
ChibiM
ChibiM's picture
Hi,
They are kind of unique, but not a special edition.
The actual special editions are called Tones, and are numbered from 1-4 or 1-8 depending on the type.
agungz
ChibiM wrote:
Hi,
but that unique version, is it still original and not fake?
ChibiM
ChibiM's picture
Yeah, they look legit.. I think they are 2nd gen Eneloops
