I’m really liking all the recent Convoy flashlights being added to the store. I hope this keeps up going into the future!
I am glad to hear that you like the recent Convoy flashlights we added to our website. We will try our best to add more flashlights. Thank you.
Weltool W5 699LM LEP Flashlight w/2*22430 Batteries
authentic / 2-mode / 2807m throw / 1970000cd / 2*22500/2*22430 / USB-C charging / IP67
Weltool W5 LEP search flashlight throwing distance up to 2807 meters! The luminous flux is 699 lumens, and the beam intensity reaches 1,970,000 candela. It uses two 22500 or 22430 lithium-ion batteries. You can also purchase an extension tube and use two 21700 lithium-ion batteries to increase runtimes. High-quality temperature control driver chip, constant current drive and ensure that the flashlight will not overheat.
W5’s LEP light source has high energy density, and after passing through a special lens reflection system, it forms a dazzling beam of light. High and low brightness modes, side-press electronic switch, with battery indicator light, and lock function. W5 has almost no spill, suitable for field search, sea rescue, long-distance indication and other purposes.
Instructions:
- First install the battery correctly.
- The flashlight has a polarity protection function. If the battery is installed incorrectly, the flashlight will not be damaged, but it will not light up. Please check the battery in time.
- After installing the battery, when it is not turned on, press the side switch once, the battery indicator on the switch turns on for 5 seconds and then automatically turns off (full battery: green light, low battery: red light, ultra-low battery: red light flashing)
- Press the switch for a long time to turn on or off the flashlight. When the flashlight is turned on, the battery indicator will be on (full battery: green light, low battery: red light, automatically turned off after 5 seconds), and the red light will always flash when the battery is ultra-low. Short press the switch to switch the mode, the default is low light mode when the flashlight is turned on.
- During use, if the battery power is low, the battery indicator will show a red light, and it will turn off after 5 seconds. When the battery is ultra-low, the indicator light will keep flashing. Before the battery power is exhausted, the main flashlight will flash to indicate, and then it will stop working at any time.
Switch lock and unlock function:
- In the off state, press the switch more than 5 times to lock or unlock:
- The main light flashes quickly 2 times to indicate that it is locked;
- After unlocking, the main light will light up in low light mode.
- After being locked, the flashlight will memorize the locked state. At this time, it needs to be unlocked when the battery is replaced and used again.
Specifications:
- Reflective system: Double convex lens
- Beam divergence angle: 1.8’
- Light source: Special LEP module, wavelength 400-700nm, lifespan is about 10,000 hours
- Switch: Side-press electronic switch with lock function to prevent accidental touch
- High efficiency constant current drive circuit, no noise and no PWM
- Temperature control protection: When the temperature of the flashlight is too high, the flashlight will automatically reduce the brightness to prevent overheating
- Low voltage reminder function (battery indicator + main light flashing reminder)
- With battery over-discharge protection
- Wear-resistant thread
- Pass the 1-meter drop test
- Double O-ring waterproof, protection level can reach IP67
- Head diameter: 60.5mm
- Body diameter: 30mm
New Arrival! Convoy C8+ 449-453nm Blue LED Flashlight
OSRAM KB CSLNM1.14 emitter / 4-mode / 1*18650 / IPX6 / 100m throw / 4.8A output / SMO reflector
Head diameter: 44.5mm
Tube diameter: 25.2mm
Controller instructions:
- Now we offer another controller version, which has 4 simple modes to switch, which is very suitable for normal users.
- Modes: 0.1–3–30–100 (the maximum current output is 4800mA).
- Its biggest advantage is that you can not see frequency in any mode and there is temperature control.
- You can control the flashlight. The temperature should not exceed 55 degrees Celsius. If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If it is higher than 55 degrees Celsius, it will constantly adjust the current so that the flashlight does not overheat.
New Arrival! Convoy M1 LED Flashlight
I also recommend you another new arrival Lumintop GT Nano 450LM 6500K EDC LED Flashlight w/10180 Battery
OSRAM OSTAR Projection Compact KW CSLNM1.TG emitter / smooth/stepped ramping / w/Micro-USB charger / IPX8 / 300m throw
GT Nano is the 10180 battery version in the classic BLF GT family. It is a super tiny yet ultra throw keychain flashlight. With a length of 52.5mm and 17g in weight, this tiny flashlight can burst into a max of up to 450 lumens output and up to 300 meters amazing throw. The included 10180 Li-ion battery and a Micro USB charger allow the flashlight ready to use and easy to be charged. Defaulted smooth ramping UI, optional advance settings, IPX8 waterproof, GT Nano is a must-have for your EDC collection.
Specifications:
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
User interface:
- By default the GT Nano is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5A TURBO mode is also provided.
- A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
- MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.Driver: Texas Avenger FET driver
Button: Tactile with back-lit rubber boot
Reflector diameter: 20.8mm
Waterproof: IPX8 (Submersible to 2m)
Head diameter: 24mm
Light intensity: 23400kcd
IMALENT MS03 LED Flashlight
authentic / 3*Cree XHP70.2 / 6-mode / 13000LM / pure white / 1*21700 / USB-C rechargeable / lanyard / IPX8 waterproof (2m underwater)
Enter coupon code MAP on the shopping cart page to get $43.25 off
- Voltage: 3.7-4.2V
- Head diameter: 36mm
- Tube diameter: 27mm
- Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature.
- Battery level indication
- 1.5m impact resistant
The prices include Europe VAT like Aliexpress?
I don’t think so, FT gives net price. But you can tick the box at payment to include it. It’s 8% AFAIR.
Thanks, I didn’t see it. Much better than pay Spain Customs that costs 4 € + 21 % of VAT.
Can Fasttech ship 18650 batteries to Malaysia and Singapore now?
The VAT is not included in the prices. If you want to have the VAT pre-paid, please tick the “Opt-in to pre-pay EU VAT for hassle-free deliveries” option in step 3 of the checkout.
Please feel free to contact us if you have any other questions.
I am sorry that we still can’t ship 18650 batteries to Malaysia and Singapore at present. We keep searching for other couriers and will update it on our website if it is available in the future. Hope you can understand. Thank you.
FastTech 2022 CNY 10% off Site-wide Sale (Coupon Code: TIGER2022)
Dear Valued customers,
The Lunar New Year (Year of the Tiger) is coming. Hope the rising sun will bring with it bundles of joy, health, wealth, happiness, and luck. Happy Chinese New Year!
We’ve prepared a 10% off site-wide promotion for you! It’s time to save more!
CNY Site-Wide Coupon
Offer: Site-wide 10% off
Valid Date: Feb 1st, 2022 - Feb 3rd, 2022 (UTC-6)
Customers can buy gift certificates Paypal or credit card to get an extra 3% free value instantly.
Dear Fasttech, it seems your shipping partner died.
Everything was OK until mid of December. Since then I haven’t received any of 6 ordered packages. For comparison, Banggood free shipping door to door takes no more than 10 days. Aliexpress shipping takes 4 weeks at most.
I gave up ordering at FT and waiting for any delivery from yours. This means you’re loosing money, because I switched to other shops that has no problems with deliveries.
Order Placed:
Saturday, November 6, 2021
Order Number: D110676174
Order Placed:
Saturday, December 11, 2021
Order Number: D121147088
Order Placed:
Sunday, December 12, 2021
Order Number: D121283214
Order Placed:
Tuesday, December 14, 2021
Order Number: D121428891
Order Total: $45.64
Order Placed:
Monday, December 27, 2021
Order Number: D122782221
Order Placed:
Tuesday, January 4, 2022
Order Number: D010485823
Nah, you’re just a bit of unrealistic and impatient
Sometimes. But more often month - month and half. (with the exception BG EU warehouse orders)
Sometimes. But more often 2 months. Sometimes even more.
And yes, I live in the EU too.
I don’t see anything out of order in your shipments above. Maybe this first one from november, but then again … 11.11. sales, christmas sales, new years sales, worldwide covid situation, cancelled flights, lockdowns … so please, stop overreacting about “no more 10 days from China” please. You’re not new into all this and you should know it better when you order from China. I can’t get even one simple shipment from not so distant Poland to Slovenia in less than 10 days or so nowaday.
My black Friday (end of November) order came two weeks ago to Canada.
Everything was OK until mid of December. Since then I haven’t received any of 6 ordered packages. For comparison, Banggood free shipping door to door takes no more than 10 days. Aliexpress shipping takes 4 weeks at most.I gave up ordering at FT and waiting for any delivery from yours. This means you’re loosing money, because I switched to other shops that has no problems with deliveries.
Order Placed:
Order Placed:
Order Placed:
Order Placed:
Order Total: $45.64
Order Placed:
Order Placed:
I am sorry for the delay in shipping your orders and the negative experience you have had on our website.
Due to the peak season and the overload volume of packages in the China postal service, packages shipped through registered airmail by China Post are severely delayed since late November. We have realized it and kept searching for other faster couriers.
We just checked the tracking information of your orders, among the 4 orders placed in December, 3 orders arrived in Poland on Jan 20, and one order arrived on Jan 25. Please wait one more week for the delivery or further updates. If you still haven’t received it after one week, please feel free to contact us. In the meantime, we will keep monitoring them and let you know once we have any news from the post office. The tracking information of the order placed in November was stuck on Dec 3 and hasn’t been updated for a long time, we have submitted an investigation to the post office. Please rest assured that if the post office confirms that it is lost or returned, we will contact you immediately and resolve it according to our company’s policy. Your understanding is highly appreciated.
The newest order placed on Jan 4 was just shipped on Jan 22, we will chase the post office to update the information on the tracking website as soon as possible.
Should you require any further assistance, do not hesitate to contact us.
More of these, please…
XHP50.3 HI LED
Light Up Your Outdoor Adventures - UP TO 22% Off
Limited offers, don’t miss out!
COUPON CODE: DEALS
Any Manker coupons?
