Always fun to see someone else’s reflows and tricks, thanks for making the video.
A spectrometer test would be nice, I always prefer (also) a measurement with a reflector on the led and measuring in the hotspot of the beam.
Colorimetry results would be welcomed indeed, and like Djozz said, a real world measurement is preferable, especially not a bare LED measurement with the device right above it.
Something like a spot/corona/spill measurement with a reflector like this doesn’t take too long to do and is quite informative about the LED.
Interesting thing for a great price.seems like the temp-regulation feedback is completely done inside the heater itself, a simple mechanical bi-metal thermostat? The 260 degrees is a bit high for reflows with simple 63/37 Pb/Sn solder, more appropriate for the higher temp solders.
This looks very useful. I noticed there is an option to purchase with US plug, but the voltage states 220V. US wall outlets operate @ 120V. Do you know if it will operate at 120V and still reach full temperature?
I want to say yes, but I suppose confirmation is needed about the exact heater used in this one. These are ok, if you get one that a) works and b) lasts, and if you inspect/mod it for safety upon receipt. I got this similar one on Amazon awhile back and used it a number of times…nice that it includes some silicone foot covers where most don’t. The price has gone up to $16 but it might be worth it for easy returns if needed. They get hot fast and are hot enough to be at the max acceptable for robust white emitters so paste on prepped components is best, and work fast, be ready to remove pretty quickly for cooling. I put a small block of 1/4” 6061 on mine in an attempt to slow down the rate of heating and that worked better. The power cord is chintzy and needs support (strain relief but also so you don’t dump the works with a shift in leverage).
But…around the holidays Sainsmart had a good coupon and I bought one of their super nifty little heaters. It is Small, but perfect for led boards! It’s programmable and has presets, wider range of temperatures, and something that approaches a good proper curve for preheating. It really works great and I think it was worth the cost. Actually extremely well made and constructed, with a very simply removable heat plate/heater if that’s ever necessary (or maybe they’ll bring out a larger one?)…I was surprised with the quality, certainly commensurate with the pricing. Need a fairly beefy power supply for it - theirs is good quality and the combo seems to still be cheaper than what you can buy them for separately. These are on Amazon as well if you google the model number - didn’t look just now but three times I checked they had the better price on their direct website (shipping is free for this amount).
There is a graph showing 3V XHP 50.3 HI (Page 23), but no retailer seems to have it yet. Once it comes out, I’m going to bug Mateminco to put four of them in a MT04. This would be my ultimate night walk light.
It sounds more probable to me that they forgot that there is no 3V HI when copy pasting the chromacity shift graphs (they’re identical), than forgetting to list the 3V HI models.
