New Arrival! Convoy C8+ 449-453nm Blue LED Flashlight
OSRAM KB CSLNM1.14 emitter / 4-mode / 1*18650 / IPX6 / 100m throw / 4.8A output / SMO reflector
Head diameter: 44.5mm
Tube diameter: 25.2mm
Controller instructions:
- Now we offer another controller version, which has 4 simple modes to switch, which is very suitable for normal users.
- Modes: 0.1–3–30–100 (the maximum current output is 4800mA).
- Its biggest advantage is that you can not see frequency in any mode and there is temperature control.
- You can control the flashlight. The temperature should not exceed 55 degrees Celsius. If the temperature of the flashlight is lower than 55 degrees Celsius, it will output full current. If it is higher than 55 degrees Celsius, it will constantly adjust the current so that the flashlight does not overheat.
