It’s a really nice light! One oddity is that the included 21700 cell is significantly larger than any other 21700 battery I have; it won’t even fit into any of my chargers or 21700 lights.
Yeah the included 21700 is quite large but fits in my Vapcell S4 charger. Surprisingly the much smaller LG M50 21700 battery works just fine with the MR50.
I received the Wuben C5 the other day. Some thoughts:
- It’s exactly as slippery as it looks, which is “very.”
- The UI is ok. I’d rather have double-click from off be turbo instead of strobe. Not memorizing moonlight when accessed via a hold from off is nice though.
- Good mode spacing.
The tint is horrendous, unless you like a green hotspot with purple spill.
The LED on mine was quite a bit off-center. It didn’t bother me too much because the tint was so bad I knew I’d never use the light anyway. I began trying to remove the bezel for an emitter swap. A heat gun plus grippy rubber gloves wasn’t working. I got fed up and used two pliers. The gouges give the light some much-needed grip. They used lots of threadlocker
My iron had trouble melting their solder. I think the centering issue was due to the weird bowl-shaped gasket they used. I guess as a plus it prevents electrical shorts on the underside of the reflector - something I’ve been having trouble with lately. A 16mm MCPCB requires no modification.
With a 219b 3500k the light is much better. I can see LED petals and slight off-centering if I look for it. I think I’ll add some diffusion film and it will be perfect.
I feel it was a good deal at $10 (plus $5 and lots of aggravation for a new emitter). I see it’s at $26 now. I think there are much better options at that price point, especially if you are even somewhat of a tint snob like me.
