Amazon Deal Alerts & Discussion Thread
Plus if you get the gold one, the tint isn’t the ugliest thing about its color :wink:
I concur. Great light.
I’m amazed these sometimes go for around $20 on Amazon. They look and feel like $70 lights.
Niwalker ET mini v1 $19.49 for the black version with an 18350 included.
https://www.amazon.com/gp/product/B097K8VLYB/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Yeah the included 21700 is quite large but fits in my Vapcell S4 charger. Surprisingly the much smaller LG M50 21700 battery works just fine with the MR50.
I don’t like the way it compresses the springs so much —- I might be converting this cell to unprotected
Flashlight Plasma Lighter 2 in 1 Combo [2Pack]
$29.98 with prime
https://www.amazon.com/Emergency-Tactical-Flashlight-Rechargeable-Resistant/dp/B09F3WRXJR/ref=sr_1_49_sspa?crid=1CRWEMK29QA7G&keywords=flashlights&qid=1642802631&refinements=p_85%3A2470955011&rnid=2470954011&rps=1&sprefix=flashl%2Caps%2C61&sr=8-49-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFZWVNFNEUwNDVSVVUmZW5jcnlwdGVkSWQ9QTA0NDA3OTkxQUxFUEhZMzhQRzBUJmVuY3J5cHRlZEFkSWQ9QTA3MjExMDIyRkMyNEhJQVU0UVUyJndpZGdldE5hbWU9c3BfYXRmX25leHQmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
[quote=Bwana]
So a plasma lighter gets its 'fuel' from the battery?
[quote=Nachtfeuerzeug]
Yes. All of these various plasma lighters on Amazon are battery powered.
There is 18650 tubes (plus clip) sold at their store for $9.99. :person_facepalming:
http://www.niwalkerstore.com/index.php?route=product/product&product_id=94
Seems like a decent UI, at least it has shortcuts to firefly and turbo.
It’s funny over the years I’ve bought seral of the double head type lights — after the initial novelty wears off , they usually never get used
I received the Wuben C5 the other day. Some thoughts:
- It’s exactly as slippery as it looks, which is “very.”
- The UI is ok. I’d rather have double-click from off be turbo instead of strobe. Not memorizing moonlight when accessed via a hold from off is nice though.
- Good mode spacing.
  • The tint is horrendous, unless you like a green hotspot with purple spill.
The LED on mine was quite a bit off-center. It didn’t bother me too much because the tint was so bad I knew I’d never use the light anyway. I began trying to remove the bezel for an emitter swap. A heat gun plus grippy rubber gloves wasn’t working. I got fed up and used two pliers. The gouges give the light some much-needed grip. They used lots of threadlocker :frowning:
My iron had trouble melting their solder. I think the centering issue was due to the weird bowl-shaped gasket they used. I guess as a plus it prevents electrical shorts on the underside of the reflector - something I’ve been having trouble with lately. A 16mm MCPCB requires no modification.
With a 219b 3500k the light is much better. I can see LED petals and slight off-centering if I look for it. I think I’ll add some diffusion film and it will be perfect.
I feel it was a good deal at $10 (plus $5 and lots of aggravation for a new emitter). I see it’s at $26 now. I think there are much better options at that price point, especially if you are even somewhat of a tint snob like me.
Thank you. Grabbed one just for it’s quirky looks. Haven’t bought a new light in a while. For $20, what the hell.
https://www.amazon.com/Cold-Steel-Folding-Tri-Ad-Handle/dp/B0851QHMJZ
Cold steel 4 max scout. aus10A version. about as cheap as i’ve seen it at 65 dollars
Here’s a good deal on a AAA Wuben light. 50% off with coupon puts it around $10.50 and comes with a battery. No 10440 though I don’t believe.
https://www.amazon.com/WUBEN-Keychain-Flashlight-Waterproof-Emergency/dp/B096B33SFR/ref=sr_1_11?keywords=wuben+flashlight&qid=1643226201&sr=8-11
That does look like a good deal!
It only comes in cool white, which I'm not too fond of, but at least it has a tail switch, something I like.
XP-G3
This guy is still at $16.oo with the coupon Wuben T2. I have this light and like it a lot. It stays in my car and feels bullet proof.
https://www.amazon.com/WUBEN-T2-Flashlight-Flashlights-Waterproof/dp/B09NQ1VFRX/ref=sr_1_7?keywords=wuben+flashlight&qid=1643228534&sr=8-7
Peetpen 70% off. $9.19 I have this one too. Cool little light.
https://www.amazon.com/PEETPEN-Flashlight-Rechargeable-Resistant-Flashlights/dp/B08P4QHC6J/ref=sr_1_27?keywords=wuben+flashlight&qid=1643226201&sr=8-27
Rovyvon clone for $13.60 or so
https://www.amazon.com/ZIXEAR-Flashlights-Rechargeable-Super-waterproof-Multifunctional/dp/B09L28P2DZ/ref=sr_1_192?keywords=led%2Brechargeable%2Bflashlight&qid=1643229084&sr=8-192&th=1
COB and Spotlight headlamp 80% off. Comes to $4 or so
https://www.amazon.com/Rechargeable-Headlight-Waterproof-Headlamps-Flashlight/dp/B09LLQYZJ2/ref=sr_1_55?keywords=led+rechargeable+headlamp&qid=1643230207&sr=8-55
Have not used the E01, but if built as well as the E05, I would say that is a great deal.
I have the E6 on me today. Such an impressive light. I have the T2 as well. So far, I have confidence in their build quality for sure.
I got a coupla those, but be forewarned. :laughing:
First, it’s got a CW G3, so… enough said.
Second, if I’m remembering right, this is the one that’s all too quick to jump to epilepsy mode if you try changing modes the slightest bit too quickly.
I literally couldn’t give ’em away.
I normally like Wubens for awesome hardware, but retarded UIs. The exception being the TO46R which I loooooooooove. :heart_eyes:
