New Arrival! Convoy M1 LED Flashlight
I also recommend you another new arrival Lumintop GT Nano 450LM 6500K EDC LED Flashlight w/10180 Battery
OSRAM OSTAR Projection Compact KW CSLNM1.TG emitter / smooth/stepped ramping / w/Micro-USB charger / IPX8 / 300m throw
GT Nano is the 10180 battery version in the classic BLF GT family. It is a super tiny yet ultra throw keychain flashlight. With a length of 52.5mm and 17g in weight, this tiny flashlight can burst into a max of up to 450 lumens output and up to 300 meters amazing throw. The included 10180 Li-ion battery and a Micro USB charger allow the flashlight ready to use and easy to be charged. Defaulted smooth ramping UI, optional advance settings, IPX8 waterproof, GT Nano is a must-have for your EDC collection.
Specifications:
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
User interface:
- By default the GT Nano is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5A TURBO mode is also provided.
- A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
- MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.Driver: Texas Avenger FET driver
Button: Tactile with back-lit rubber boot
Reflector diameter: 20.8mm
Waterproof: IPX8 (Submersible to 2m)
Head diameter: 24mm
Light intensity: 23400kcd
