[Review] Lumintop Thor II (LEP, 1800M, 18350, 769500 Candella, Turboglow)
Today I have a fun one, with a new LEP light from Lumintop with the THOR. It has a Turboglow ring in the head as well as little viewing windows and a tail cap with colored LED’s. Thanks to Lumintop for sending this to me to look at and review. I will have links to where you can pick it up from them in the description below as well as a coupon code where you can save 21% on this light, check the YT video for that.
Watch this review on YouTube:
Follow me on Instagram: Jon (@liquidretro) • Instagram photos and videos
Join the Facebook Page: Liquidretro Gear & Reviews
Enjoy this review? Buy me a Coffee/Beer: https://www.buymeacoffee.com/Liquidretro
Packaging & Accessories
I received a retail package, that was Lumintops cardboard box with an oversleve. The outside showed the outline of the light, and the options that were inside on the side. Accessory wise mine was pretty basic, just the light, 18650 extension tube and the basic manual.
Construction
The Thor is available in a couple different material configurations. You have titanium options with 2 different finishes, and an aluminum model with 4 different color options (Black, Grey, Sand, Raw). I have the Grey color here which is the same as what the FW3A came in originally if you have one of those.
As usual let’s start at the tail cap, the light will tail stand, and it has a machined metal mechanical button with the “old” bunny logo. Surrounding it is a clear plastic ring. Under the ring are RGB LED’s that fade to Green, Yellow, Red, and Blue over about 30 seconds. It adds to the fun in my opinion. Below are some tear drop shapes, and a small place for a lanyard to attach. Inside there is a spring.
Depending on which configuration your running there may or may not be a body section. With the titanium version of the light, it includes the 18350 extension, with the aluminum version it’s an add on. If you do opt for it it allows you to run 18650 batteries too. There is a square knurling pattern milled into it for a little style and grip.
The head section is the rest of the light, You have an interesting add on style ring which on my light is gold in color. This features the name and serial number of the light. Fit on mine isn’t great so it spins freely but it’s also completely removable if you wish. The head has a little more of the square milled knurling and the ngrows for the emitter like a traditional flashlight shape.
What’s not so traditional are the little windows that are cut into the bezel, what looks to be preinstalled tritium is actually little vial sized pieces of Turboglow in Red and White. When the light is on, light leaks into these and charges them creating a neat effect that makes the light look really cool when in use and after for a little while.
The front of the light has a glass lens, underneath is a glow ring around the outside edge of the same Turboglow material. Underneath is a biconvex lens made of plastic, and below that is the emitter. The front of the light comes apart easily, but I don’t recommend it as it’s very hard to get back together without getting dust inside.
Size and Weight
Minimum diameter is 25.6mm, Maximum diameter was 41.5mm. Length in the 18350 configuration is 116mm, with the 18650 extension it’s 148.4mm. Weight in 18350 configuration with a battery inside was 194.4g. Weight with the 18650 tube and battery came in at 233.6g. The light is impact resistant to 1m, and IPX8 water rated.
Retention
Not much to say here, the light has a lanyard attachment point in the tail cap. It’s too small for paracord to fit but fine for a split ring and then paracord. No lanyards or holsters come with the light in the box.
Emitter & Beam
The THOR is using a LEP or Laser Excited Phosphor. It’s a technology I have covered in the past but it’s similar to a blue laser shining onto a piece of phosphor to produce white light. In the Thor the tint here is better then my Jetbeam and Astrolux LEP lights, in my opinion because it’s less cool white, and more neutral, almost slightly warm when you look at them side by side. The beam is pretty small with very little spill and this is exactly what you want out of a LEP. While not many lumens it makes up for it with extreme 769,500 Candella, and a 1800m max claimed distance. No PWM is visible during the use of the light.
Heat & Runtime
I tested the light both with 18350 (Keeppower 1100mAh), and an 18650 (Sony VTC6 3000mAh) batteries. With the 18350 runtime at high mode was stable for right at 5 minutes, before taking a stepdown to about 30% relative output that was mostly flat out to 52minutes. Total runtime was 57 minutes, with maximum heat being found at 6 minutes at 42C .
With the 18650 it was a very similar story, Turbo lasted the same amount of time, the s tepdown roasted out to 2:45:00, and total runtime ended at 3:07:00. Temps were a a little higher at 51C and peaked near the end of the runtime here.
You don’t need a high amperage battery here, as max power draw is only 9W. You do get quite a bit more runtime with an 18650 battery so that’s worth doing if you want/need that.
UI
The UI on the Thor is very simple, it’s an easy 3 mode light with a reverse clicky mechanical button and linear progression from Low to Medium, to High. The light will always turn on in the next mode. The button itself is quite easy to press and change modes by half clicking, almost too easy. There is no flashing or blinking modes, and I can’t find a way to disable to LED’s in the tail cap either if you wanted.
Conclusion
This is my favorite LEP light that I have so far, because it’s emitter is a more neutral, almost warm color and it’s performance is great, especially when your running the 18350. That said I would definitely recommend adding the 18650 extension it to your order if you decide to buy this light in aluminum. Really for this price it should be included.
I still maintain LEP lights are not super practical, but they are a lot of fun and great for specialized applications. This is a super compact thrower with great performance without the heat limitations that a lot of the smaller LED based throwers have. It’s a step above the other LEP lights that I have tested this year. While I love titanium the increased cost here is hard to justify, my recommendation is to choose aluminum and pick one up.
bonjour et merci pour cette revue très détaillée , que me conseillez vous entre la version 1 et la dernière version 2 de la thor 2 ? apparemment , la version 2 possède uniquement le mode low et high , ainsi que le mode stroboscope , comparé à la version 1 qui n’as pas de stroboscope mais qui a le mode low , medium et high , merci d’avance pour votre retour .
PS: le tube d’extension 18650 pour la version 2 est très différent du tube d’extension de la version 1 , celui de la version 2 est mieux réalisé et avec un interrupteur arrière , mais son prix est presque le triple de la version 1 .
With some help from Google Translate I think I understand. I have only looked at the Thor 2 and Thor 3, so I can’t really give opinions on the Thor 1 unfortunately.
sorry, I’m having trouble expressing myself sorry, I’m talking about the thor 2 like yours, but the version 2.0 that lumintop released, and which is already available on aliex, is exactly the same as yours, except that it is version 2.0 which only has two intensity modes: low and high and the strobe mode.Cordialy.
Ah I didn’t realize they had updated the UI. Having more then one mode is nice but I find myself only really using the highest output on the LEP lights that I have typically.
bonjour et merci pour votre réponse ainsi que votre aide , votre dernier message m’as bien aidé étant donné que c’est ma 1 ère lep flaslight. Merci pour tout et bonne continuation . Cordialement :slight_smile:
