【convoy】H4 and B35AM options are updated
Is there an OP reflector available that fits the L2?
Can an Osram W1 Red be driven with an 8x7135 biscotti driver? I got an RGB C8+ set and it bugs me that the red has a different UI. I’m considering swapping in a spare biscotti driver I have but I don’t want to burn out the LED or anything.
These are about as durable as the white emitters but they derate a little with heat. Datasheet rates 2.5A max with 3.3A pulse, plots look good like the white so it should be fine as long as you keep it in normal thermal cutoffs (80°C is a killer at 2.5A but…). Actually pretty impressive for a color emitter. That said, I don’t know how much is to be gained above 2.5A but it shouldn’t hurt it at all…8x7135 is usually around 2.7-2.8 anyway with the 350mA chips and didn’t increase much with the 380mA.
Datasheet here: https://dammedia.osram.info/media/resource/hires/osram-dam-5961110/KR%20CSLNM1.23_EN.pdf
Awesome! Thanks so much Correlux!
Edit: I just opened up the light and I see this 4R7 thing and some red glue looking stuff. Is that a buck converter and potting compound perhaps? I don’t see the same component or glue on my 5A linear drivers in my Green and Blue C8+’s. If so, then switching to a 7135x8 driver should produce significantly more heat, right?
It’s an inductor…not sure about the driver particulars there and Simon’s product pages are invisible for awhile yet. The coating is not potting compound…it’s a “conformal coating” which is kind of like solder mask, just used to help protect against oxidation and dust, potential shorts, etc. It’s a nice professional touch although the way they often do it with cheap electronics is kinda half-arsed and at times doesn’t make logical sense, but…better than nothing (until you want to desolder things). The 7135 will usually run warmer until voltage drops…they do their job but not efficiently.
Gotcha. Thank you so much for all your help!
only smooth reflector
yes, suitable
It’ll work, but doesn’t run very well. It operates at a higher VF so you’ll get less efficiency. You lose 40% output very quickly. Stick with what’s in it
This is with the 8*7135 biscotti driver. Used this in my first lot of stock when I first started using the Osram red. I stopped after running this test.
Here is the new driver in the L21B
My review of the H2 headlamp. Thanks Simon for sending it
Have a good holiday Simon!
Simon, thank you for producing these colorfu C8+’s! They are delightful, especially with diffusers.
This must be one of the most beautiful beam shots Ive ever seen. Your use of a wall corner to mix 90 degree beam and color convergence was brilliant. If its a Photoshop, it certainly fooled me. Well done!
Thank you! I’m quite proud of how that turned out. The only editing was cropping it into a square, haha.
The L8 tube doesn’t fit the M3 or the L7 unfortunately
will b35am be available in warmer temps? 2700-3000k?
Hi, Simon, I hope you’re enjoying your holidays! Any plans for s21d with clear narrow optics? And what about putting 519a in?
I like this idea, but I would prefer narrow frosted optics.
Also, I would settle for an S12 with 519A’s.
Simon, any chance you would stock 519A in 5000K (or other temperatures) in the future?
Some modders reported very good results slicing the 519A, which has the side effect of lowering the temperature. Thus, to start with a 5000K emitter should give an end result of about 4500K, which is desirable for many.
Happy New Year, Simon :partying_face:
