It’ll work, but doesn’t run very well. It operates at a higher VF so you’ll get less efficiency. You lose 40% output very quickly. Stick with what’s in it
This is with the 8*7135 biscotti driver. Used this in my first lot of stock when I first started using the Osram red. I stopped after running this test.
This must be one of the most beautiful beam shots Ive ever seen. Your use of a wall corner to mix 90 degree beam and color convergence was brilliant. If its a Photoshop, it certainly fooled me. Well done!
Simon, any chance you would stock 519A in 5000K (or other temperatures) in the future?
Some modders reported very good results slicing the 519A, which has the side effect of lowering the temperature. Thus, to start with a 5000K emitter should give an end result of about 4500K, which is desirable for many.
If the 519As become available in the S2+ (and other lights) in a range of colour temperatures from 2700k to 6500k, I can see myself buying quite a few for night photography (replacing my LH351Ds).
Simon, did you ever get a round to do some measurements? If not, I’m assuming you’re enjoying a well deserved vacation
+1
Would love to have a high CRI alternative to the LH351D in various temperatures. Already have too many LH351Ds and I’m done with SST-20, which is too narrow beam and only 2700 and 4000K (low CRI of colder ones is a no go).
I remember when Simon released the driver first red W1 Osram, and iirc it was made more so for the lower voltage frequency of that LED not necessarily the low amps.
Couldn't a red W2 be used with 8*7135 more efficiently? I have used a couple, but I've never looked up what they're Vf is.
