I tinkered a bit with Convoyās 12V 2,5A GT-FC40 driver. I changed it to 6V output and adjusted boost converters input limit to higher value. It was limited to 10A, but MP3431 boost converter should handle higher. I also changed bigger 1R5 valued inductor to it from broken Convoy driver. With 6,7 mOhm current sense resistor mine gives an output of 6,2A and draws 12A from battery. This with battery voltage of 4,1.
I havenāt done anything with my flashlights anymore for several months, but today I added aux leds to my edc FWAA. Due to the fact that attiny85 sits inside, there is only one color - ice blue, but I think thatās enough for me. imgur gallery
I also finished a mod for a friend recently. He saw it at Vinhās and wanted it too. 7x xhp50.2 5000k mule.
Apart from the auxes, I also added a blue GITD tape to the inner wall. I think it was a good idea. imgur gallery
Just for fun to see what would happen and get some practical experience with flashlight modding; Convoy L2 with B35AM. Maybe a high CRI thrower.
Iām considering this a work in progress. Some practical limitations, such as no OP reflector available and unfortunately no 2 cell 6V driver (used the 20mm Convoy B35AM driver). The dedicated B35AM gasket is just too small for the reflector hole, so had to use a unknown gasket that was much thicker, but fits (possibly XP). Also the stock L2 tail button is not suitable for controlling it. Need to find a replacement for that. But Iām was pleasantly surprised by the beamshot. Was expecting something floodier, but it actually shoots out pretty straight. It throws further than the DM11 with B35AM. But up close there are rings that I would like to get rid off, just donāt know the cause.
@Verodin, I believe those rings could be reduced by a flatter, more shallow gasket. The emmitter just needs to be level with the base reflecting surface of the reflector. It really isn't that bad and the beam is nice. The color comes from the lens anti-reflective coating.
Installed an LED Lenser-type optic (out of a Jobsmart Tractor Supply Company headlight that I was planning to give away) into an S21A. Also found an e-switch that may be a good replacement for a D4 switch. The beam is a fixed, broad hot spot from the floody LH351D at 4000K. A beam kind of like a CO1S.
Tue, 02/15/2022 - 00:15
Today, had to run to TSC for something else and they still have these. I'm glad I had it for parts but I wouldn't pay $12.99 for an optic.
Itās mainly that white outer ring thatās distracting, the coating colour is barely visible. During real life use I mean, not white wall. I plan on using the original gasket, but with something around it with the same height to level them out. Then see what difference it makes (ring + beam). Also noticed some artefacts in the beam, but only over 5m distance. Darker center mainly, not a distraction outside, as long as you donāt point in at white snow.
After the initial post I went outside to play more with it. This will be a keeper apart from tweaking the stuff just described. The only real throwers I have are all cold white with low CRI. This one lights a small area, but the colours definitely pop more, itās a clear difference, even without comparing directly.
