I’m in! Looks like an interesting light!
Nice looking light. Magnet in tail?
Thanks for the giveaway!
This is similar to sofirn SC31 pro (that has 3 color versions), so price wise would be taught to spend $52.98 for me on it, as I already have sofirn SC31 pro (with addons like 18350 tube, and magnetic tailcap).
overall it looks quite good for EDC flashlight.
- is it constant current driver, hybrid, or FET?
- is there option for magnet in the tail? addon?
- Is there option for better mounted deep carry pocket clip, similar to new KR4 clip? (so that it can't be lost)?
+ 1 for high CRI led option (the SST40 have like only 65 CRI)
Thanks for this GAW VezerLezer
Looks interesting, especially like the “spline” knurling (reminiscent of the Zanflare F1).
Sure, I’m in.
Man that’s a good looking light!
Good looking light, seems nicely built.
I suggest you get rid of the 2600mAh 18650 and include a high discharge 3,000mAh cell instead.
Wow. Looks very good. I love this.
Charles BridgTec has a review on this light, released today!
I will say that I am pleasantly surprised with the flashlight, as far as I can tell
Thanks for the opportunity. You have come up with a very interesting brand name.
There’s no magnet in the tail. You could probably fit one in under the spring but the protected 18650 may fit tightly. The head also has a spring. An unprotected flat top may work well with a magnet under the spring.
ED10 reflector is about 15% bigger than the SC31 Pro reflector.
ED10 has OP while SC31 Pro has SMO reflector.
ED10 is slightly shorter than an SC31 Pro with a non-magnetic tailcap.
ED10 is slightly wider than an SC31 Pro.
ED10 charge cover sits flush with the head while the charge cover in an SC31 Pro sticks out. SC31 Pro cover feels more durable.
ED10 tailcap is smooth while SC31 Pro tailcap without a magnet has a sharp edge (lanyard hole).
ED10 metal button feels nicer IMO compared to the rubber switch cover in the SC31 Pro.
ED10 knurling looks nice but the more aggressive knurling on the SC31 Pro may be more practical in terms of providing grip.
I’ll try to remove the driver after I’ve done runtime tests.
Thanks for this GAW!
Welcome abroad! Unique name and thank you for the giveaway.
Welcome @Lezer and thanks for the GAW!
Nice looking compact and stylish design.
A tooltip on the website indicates SST40 6500K which is not going to be a favorite here. +10 for warmer CCT / high CRI!
Welcome VezerLezer.
I like the UI. Looks well thought out. I assume there’s last mode memory from one click on?
Good looking flashlight with decent UI.
I too would like to know what “Ramp Style Swap” means.
I’m in!
Seems nice, looks like sst40? Any plan to offer other emitters?
Nice entry and welcome. Looks like a good work light.
Count me in and cheers
