My driver runs around 6 amps tops out at 7.5 amp then dims and the current drops right off, i think they or some are digitaly regulated at 7.5 amps max. I have brought this up in my calling all tr-j12 owners thread. I to dont belive all tr-j11,s are made equal.
Mine appears to cut off HI at around 3V per cell, but as I suspect above theres a high likelihood not all J12s have identical DC-DC circuits. Its almost impossible to measure though because with cells depleted this far down unloaded cell voltage is much greater than voltage under load, and the cell voltage will rebound within a minute or two. Note also that my testing ONLY pertains to the TWO cell configuration. I havent tested it with 3x cells.
I have checked current on both of my TR-J12 between driver and led. One has alot of brass around the driver and the other has mostly plastic and smaller brass middle.
Using Sanyo 2600 fully charged and partially depleted gave similar results .
Got it Thursday, very nice light. Bright as can be, throws about as far as my BC40 but at that lights up a MUCH LARGER hot spot, plus everything else in sight. Still kinda want to do the KD monster driver if I can get it programmed for a Turbo mode of like 3500 lumes, then a high that’s the same as the current high, med that’s the same and a low that’s the same since the High currently it can run at for a long time and the med and low modes are pretty well spaced, and the Turbo would only be usable for a little while. Overall, I quite like this light.
Just got my Trustfire TR-J12 from this same Aliexpress retailer. All arrived in perfect condition and very well boxed. Using my 2x26650 Trustfire 5000mAh’s charged to 4.19v, on HIGH mode I get 4.10a
Finally I have a good working 26650 light. Thanks for posting about this retailer, they are as professional as it gets and sell real Trustfire products.
Just took it outside and put it up against my DRY NW on Turbo and somehow my J12 beat it. I came inside and did a ceiling bounce test between both to see what the meter showed. The Dry read 630 lux and my new J12 read 805 lux under the exact same conditions. Perhaps the fact the Dry is NW tint and the J12 has a slightly cooler tint must be the reason for it being slightly brighter. Whatever the reason, I find it amazing the Dry got edged out.
thanks richiee i ordered from ali express 1 of these as well.
Coupon code: 15noorder20120614 – coupon $5 for orders larger than $25 can be used on Aliexpress.com but only once per account.
30% off
45$ shipped they are normally 75-80$ each be quick guys sale end in like 9 days.
I’ve been trying to figure why there isn’t more hysteria about this light at this price. Great light at a great price with a proven vendor. I guess people prefer the form factor of the King better…
After seeing the issue Kramer had with his tail-spring, I decided to modify mine before a problem came up with it. I noticed the switch was the same on my Skyray 856 except the 856 uses a stronger gold plated spring soldered to the switch rather than a thinner chrome plated version as on this J12. Since my 856 has a bad driver, I figured I’d just switch them out. Works great and I doubt this heavier duty spring will suffer from any heat issues.
