Nice entry and welcome. Looks like a good work light.
Count me in and cheers
good looking flashlight. thanks for the gaw.
mos+7135
Hello,
It looks nice and compact for the power offered. I also like the UCB-C charging possibility very much.
I will check for your products from now on.
Nicely done.
The UI looks fantastic, what I’d want from a non Anduril light.
‘Ramp style swap’. Is this stepped and smooth ramp? It sounds familiar
The construction also looks familiar like sofirn SC31 but it’s different enough not to be a clone. angular pattern makes its stand out.
Any relation to sofirn?
Also does this have C to C charging? I’ve notice reports that some brands use charging chips that don’t support that.
Amazing Light, expecting more models to come.....
HCRI 4000K-5000K please.
Nice UI/modes. Looking forward to a review one day.
Welcome to the forum and thank you for the giveaway!
The ED10 looks really solid, I just wish it didn’t come only in 6500K. Nonetheless, thanks for the great GAW, VezerLezer!
looks good, welcome and thanks for gaw. good luck to all
Yes. From off, hold for 5 seconds until there’s a bright flash and it’ll switch between stepped and smooth ramping.
Yes and no. It charges when connected to my laptop dock via a USB-C to USB-C cable. But it doesn’t charge when connected to my Google Pixel USB-C PD power supply.
Just adding my name to the list - thank you!
Welcome aboard to BLF! Thank you for the giveaway!
Looks like a nice light. Hoping to see warmer options in the future.
I quite like the look of it and the UI seems tolerable. Driver efficiency, if the listed runtimes are accurate with that 2600mah battery, seems pretty good as well. Not bad for a first light from you guys if it’s as described.
Yes, it has memory, you can startup from memorzied output, or Moonlight, or Turbo.
It’s very stylish and portable, I like it. If you could add a double sided clip in the future it would be perfect.
Thank you for the Giveaway.
Great EDC flashlight! But without a warm/high CRI you won’t get far! And yet I’m in business!
