NEW high current 60V 24A 1440W power supply RD6024 is released now
RD6024 feedback
Arrived pretty quickly, packaged very well. It seems to work, I'm waiting for another power supply
https://aliexpress.com/item/1005003744641750.html
This is the same power supply and case I had the DPS5020 installed in. I just had to cut the front panel bigger to fit the new display (RD6024).
I original had a switch installed for the DPS5020 so I left it in but I soon realized the RD6024 has its on power switch but the switch is still needed to cut power to the power supply. This is a 1000 watt power supply with its case off and takes up most of the lab power supply case with just enough room for the DP6024 to clear everything. The thermal controlled fan that was in the original power supply case has been relocated to the lab power supply case and wired back to the original connection on the power supply.
This is the power supply Page Not Found - Aliexpress.com?
The case I purchased isn’t for sale anymore from the seller at Aliexpress but its size is 250 x 190 x 110mm. The front panel I made from 1/8” aluminum sheet. I wanted it stiffer than what the case came with, it was thin sheet metal.
usually when you remove the case of the input ac to dc PSU, the PSU fan is for the heat dissipation inside the PSU, now it needs to deliver the heat of the whole case, so it may have influence, if you replace with other fan which is more powerful, the influence may be lower
Its still in a case, its just the case is bigger now. The same amount of air is being moved as in the original case. I don’t know that I have actually ever heard the fan run, if it was it was very low, thermal controlled. I dont usually turn it up that high and if I do it’s usually only for a short time. I powered a small 12v air compressor off it (DPS5020) one time for several minutes at around 15 amps but that’s still only 180 watts. Thanks for the tip, I have several 80mm fans of different cfm, I can replace it with if I notice it running hot. I really like RD6024 so far, the on/off button is easier to push without having the case slide across the bench from trying to press the button. The X25A test cables are really nice also. :+1:
very good
hope you can make a good review for RD6024
when you choose a option, it will show you picture and title, that is what you can get.
RD6018 feedback
Item received in good condition and functions as described
https://aliexpress.com/item/1005001488070904.html
RD6012P feedback
Received quickly, super packaged. Checked superficially. Liked it very much. Thanks
https://www.aliexpress.com/item/1005003472332331.html
hello, use PC to open this link, you can get 5 USD coupon for RD6012P: https://rdtech.aliexpress.com/store/selected-sale-items/923042.html?es=0zoEZ8%2F9sMYX3DWa0E%2BXFeToflpxYFk2
RD6018W feedback
Everything works! :)
https://www.aliexpress.com/item/1005001488070904.html
RD6018 feedback
Works fine excellent quality
RD6018 feedback
assembly finished, it works
RD6024 feedback
very good product. Easy installation. Good communication with seller. strogly recommended
https://www.aliexpress.com/item/1005003744641750.html
RD6012 feedback
Goods delivered quickly. I can highly recommend a great device
https://www.aliexpress.com/item/4001053200176.html
RD6006 feedback
good power supply, like it
https://aliexpress.com/item/4000282551930.html
RD6012P feedback
I finally got a high-precision converter head. The workmanship is still very good. The size is the same as that of other RD series buck converter heads. It is very convenient to replace.
rd6024 feedback
The workmanship of the circuit board is very delicate and the precision is good
RD6012P feedback
good
I know that some customers like to give feedback for the products they buy, there is one thing you need to know, please hide the address information when you upload the pictures for safe reason, it is important, do forget it
RD6012P feedback
Good accuracy
