Its still in a case, its just the case is bigger now. The same amount of air is being moved as in the original case. I don’t know that I have actually ever heard the fan run, if it was it was very low, thermal controlled. I dont usually turn it up that high and if I do it’s usually only for a short time. I powered a small 12v air compressor off it (DPS5020) one time for several minutes at around 15 amps but that’s still only 180 watts. Thanks for the tip, I have several 80mm fans of different cfm, I can replace it with if I notice it running hot. I really like RD6024 so far, the on/off button is easier to push without having the case slide across the bench from trying to press the button. The X25A test cables are really nice also.
very good
hope you can make a good review for RD6024
when you choose a option, it will show you picture and title, that is what you can get.
RD6018 feedback
Item received in good condition and functions as described
https://aliexpress.com/item/1005001488070904.html
hello, use PC to open this link, you can get 5 USD coupon for RD6012P: https://rdtech.aliexpress.com/store/selected-sale-items/923042.html?es=0zoEZ8%2F9sMYX3DWa0E%2BXFeToflpxYFk2
rd6024 feedback
The workmanship of the circuit board is very delicate and the precision is good
https://aliexpress.com/item/1005003744641750.html
I know that some customers like to give feedback for the products they buy, there is one thing you need to know, please hide the address information when you upload the pictures for safe reason, it is important, do forget it
hello, this week, you can use PC to click this link to get a 5 USD coupon for ordering RD6024: https://rdtech.aliexpress.com/store/selected-sale-items/923042.html?es=0zoEZ8%2F9sMa1O%2FL%2BIxBDcRoryit2GsPS
