hello, use PC to open this link, you can get 5 USD coupon for RD6012P: https://rdtech.aliexpress.com/store/selected-sale-items/923042.html?es=0zoEZ8%2F9sMYX3DWa0E%2BXFeToflpxYFk2
RD6018W feedback
Everything works! :)
https://www.aliexpress.com/item/1005001488070904.html
RD6018 feedback
assembly finished, it works
RD6024 feedback
very good product. Easy installation. Good communication with seller. strogly recommended
https://www.aliexpress.com/item/1005003744641750.html
RD6012 feedback
Goods delivered quickly. I can highly recommend a great device
https://www.aliexpress.com/item/4001053200176.html
RD6012P feedback
I finally got a high-precision converter head. The workmanship is still very good. The size is the same as that of other RD series buck converter heads. It is very convenient to replace.
https://www.aliexpress.com/item/1005003472332331.html
rd6024 feedback
The workmanship of the circuit board is very delicate and the precision is good
https://aliexpress.com/item/1005003744641750.html
RD6012P feedback
good
I know that some customers like to give feedback for the products they buy, there is one thing you need to know, please hide the address information when you upload the pictures for safe reason, it is important, do forget it
RD6006P feedback
compared with 6 1/2 multimeter, not bad
hello, this week, you can use PC to click this link to get a 5 USD coupon for ordering RD6024: https://rdtech.aliexpress.com/store/selected-sale-items/923042.html?es=0zoEZ8%2F9sMa1O%2FL%2BIxBDcRoryit2GsPS
RD6006W feedback
The RD6006W module is very interesting, it met my needs. It is easy to operate and the real-time graph of current, voltage and power helps a lot to analyze some boards. The current limiting is also nice, works well.
https://www.aliexpress.com/item/4000282551930.html
RD6012P feedback
Great power supply. It will accompany it for the next few years of maintenance career. Perfect.
DPH5005 feedback
device very well made, beautiful and accurate. Controls are easy to configure. Super recommended!
https://www.aliexpress.com/item/32840324731.html
RD6012 feedback
Not bad. This is a pulse generator, the output noise is acceptable, about 30 mV and bursts up to 100. I use transformer power. functionality is more than great. as an additional power supply is very good.I recommend to buy.
RD6024 feedback
Packaging is excellent, everything works. Thanks.
RD6012 feedback
I have made the box with wood, and I have put a toroidal transformer on it, everything is perfect!
(note:you must add rectifier and filter, DC output voltage without load should be lower than 65V)
