For longer term storage it seems the only option. They just aren’t as temperature tolerant as straight up lithium, or so I’ve read. I don’t have much experience with NIMH. I just bought a 4 pack of AAA standard eneloops to use in some recently acquired WK1/WK2 pen lights. The only rechargeable AA’s I have are the green Energizers (which I used to test viability in the T4), and have been using them in my AA Tool backup work light. However, that’s brought in from my van nightly and rarely sees temps below 15°F.
Mine came today. It works great with Eneloops. I haven’t tried it with Energizer Lithium primaries. I’m going to be pretty unhappy if it doesn’t work, because that’s the scenario I bought it for.
Lithium Primaries and Eneloop, operate in climates where I do not operate. LOL
google sez: “Lithium primary batteries can continue to function properly at temperatures from –67°F to 302°F”
“Nickel–metal hydride (Eneloop) cells can operate in the temperature range of –4°F to 113°F”
“Alkaline batteries are best suited for operating temperatures between 14°F and +113°F”
“The use of a lithium-ion battery is possible in a temperature range of 50°F to +131°F”
I did not realize until now, that LiIon does not work below 50F… that does not ring true to me… I just put a LiIon light and an Eneloop light in the freezer, to test for myself…
Ive had these two lights in my Freezer for 4 hours… they still work. One is LiIon, the other is Eneloop:
I also have three lights in my car with AAA Eneloop, and they still work too. We have had a cold winter, as low as 10F… It seems the batteries are doing fine… they also live in the car in summer… which gets up to 90F outdoors… in the car much higher… I do not store LiIon lights in my car.
I do have a LiIon Jumper pack that lives in my car. It seemed unaffected by freezing weather, as it worked to start my car on one of the colder days this winter…
for my needs, Lithium Primary seems unnecessary, since Eneloop is working fine.
in low temps, generally capacity and max current are lower, because of slow chemical reactions.
For flashlights it's usually not to the point of it not working, but it depends on the device.
Ps. Just bought programmable bench power supply 40V/20A (will have it probably in a month).
Now I only need T4 for LVP testing, and lowest voltage for operation on AA.
If there will be a version on 12/13 mode driver and nichia 519A, I will buy it and test it.
Did a short walk with the dogs last night and my Ts21 was in my jacket pocket (Lithium Ion) and my E02 II (NiMH) clipped to the outside of my jacket. Was able to put the EO2 II into high at the end of the walk. Not sure if it would have maintained high. Sometimes when it is cold out even a fresh battery will not go to high once the battery gets cold. Low works fine even when really cold. Didn’t really use the TS21. However, when I took my coat off in the house I checked the temp and it was reading 248. Clearly the Liion batteries work much lower than 50 degrees! When I was playing with it on other cold nights I would put the TS21 on regulated level for a minute or two to get the chemistry moving. Then I could put it up to Turbo and wait to see if I could get thermal regulation to kick in. On the coldest nights I could not. Warmest temp I measured was 44 after several minutes on turbo. Last night was pretty darn cold for the second week of march but at only a few degrees below 0 F wind chill I would have been able to trigger the thermal regulation after several minutes. Did this a few times this winter and the battery seems just fine.
jon_slider - not to stray off onto a tangent, but I noticed in the pic of your ‘freezer’ lights (thank you for that experiment, BTW), you run eneloop pro’s in one of your torches. Do you prefer/ recommend them over the standard white? It seems from what research I’ve done, aside from more gas in the tank, people recommend standard over pro version. As stated, I don’t have much experience with NIMH. Curious as to your take. Thanks.
Yeah exactly. Why not just fix the problem by simply tweaking LVP, or even just offer a non-LVP version and let people choose. Should be very easy I guess.
It’s really sad since T4 has such good potential as a leave-in-the-car backup light.
I wouldn’t be confident to leave Eneloops in cars. They may not catch fire or explode or anything. But I assume they’d lose charge under extreme temps…
I prefer the white Eneloop… I have bought more white to replace the old black ones that only have half the lumen output of same age white ones… iow, the black wear out faster…
that black battery in the photo, powers a Ti3 w 3000k 219b, that lives in the bathroom. I only use the lowest mode, so the old worn down black battery works fine
I use low and medium modes on my indoor lights… no need for high mode indoors.
For a bathroom light, it does not matter that the old black eneloop only gives 30 lumens on High, nor do I need the white ones that give 50 lumens in the same light…
Trust but Verify, your assumptions
post 33 has some details of my experience (tldnr: I use Eneloops in my car lights)
Simon updated the description to say that lithium AAs don’t work with the current version. That makes it sound like there with be a fix with the next batch.
