What is the actual difference in construction between lithium primaries and secondaries? Don't need a real technical answer but a rough idea. I have several things that use rechargeable ml2032's and some use primary cr2032's. So that is something I wonder about whenever I have to make sure I use the right one. ML2032 about $4, CR2032 about 40 cents both are the same brand. Big difference for the same size little guy. I always figure I get my money worth with either of them.
In my build I’ll be drawing 24+ amps (peak - turbo). Using an eSwitch for mode selection (Anduril) and a rear clicky, reverse, for lock-out. The Omten has 1.5 A - 250V rating. Will it be sufficient? And if it doesn’t melt, will it be a bottleneck?
Originally was going to bypass the switch and make a direct tailcap to body connection. But there’s the idea of a simpler way to lockout than a quarter turn. The eSwitch can be illuminated when there is a connection.
Seems as they supply eBike batteries. So they assemble the packs but I don’t see any cell manufacturing. In one picture we see the break-in of those battery packs. But nothing of individual cells.
In the link, they have the more popular OEMs and don’t shy from the make in the photos.
If you were in my area, I’d make a joint venture and give them a try. Maybe the shipping kills the deal?
Thanks for the insight. Yea maybe the shipping kills. Minimum order is only 20 units which is much more doable then the other vendors I was seeing. Maybe I’ll give contact them and see just how bad this shipping is haha
They accept PayPal and the standard cards. As shipping, UPS, FedEx, DHL. I know these aren’t cheap to Canada, but their rates are acceptable to the States.
Now there’s one fellow that is touting (exploring) the market of protected cells (Is there a demand for protected 18650’s?). Perhaps he’s stumbled on some Alibaba vendor? I’ve had dealings with Ali and I wasn’t disappointed. The duties weren’t fully explained and I had to fork some $40 on a $60 order. It still was within the overall budget, but I hadn’t foreseen that such merchandise isn’t in the Universal Postal Union nor any special tariffs, be it was a small order of some 100 socket type LEDs.
P.S. If this company isn’t making the cells or re-wrapping, that would be a side gig selling individual cells. Their customer target would be the DYI bikes and other goods. They have quite a variety of cells and chemistries. Just saying…
I don’t know if anyone has tested and published results for those cells or the blue ones…just for the Queen Battery with the gold wraps. QB does not make those themselves and I haven’t heard anyone mention who the actual manufacturer is. We do know that the QB is a great cell in both current delivery and capacity. The specs listed on your Alibaba link seem kind of suspect to me when comparing with the specs and datasheet on the QB cell. The weight is heavier by quite a bit, same capacity, different stated standards for charge and discharge although close enough. If that weight spec is correct, where’s the extra coming from? Thicker can, good jelly roll magic stuff, thicker wrapper? That said, the form-entry specs shown on the Alibaba product page may just be thrown together without concern for truth.
It’d be nice to see some real test results on these to compare with the QB. Who knows, they could actually be the same cells. I don’t know if Simon has/would be willing to spill any beans he has about the green one…as the QB is out of stock seemingly everywhere for the moment, he’s switched to the green in his store/lights.
I guess my caution here if I were spending my money is ending up with a disappointing cell that ends up being on par with 26650 in real use. There was/is such variability in 26650 cells with few really good performers that offered anything over 18650 (and now 21700)…was a nice surprise to see the 26800 performance from QB that makes it a viable platform choice. If the green ones are lesser than the QB then may as well stick with good 26650 or even 21700.
Edit to the edit…I guess Piotr Wang is the actual company that markets the Queen Battery trademark/brand. So…who’s the real manufacturer then……mystery.
And another: The weight on the QB web page is different than what’s on the datasheet. The datasheet says 121g, which matches the Alibaba green cell’s statement. I just weighed all four of my QB 26800 cells and got: 115.75, 115.80, 115.81, 115.81.
Looking at the specs from Piotr Wang QB they are about identical to the Shenzhen Qiyun offering. Same weight (121 ±3g), same charge / discharge rates, etc.
Shenzhen Qiyun Technology Co.
Piotr Wang Power Trading Co.
In the last pic, there is a mention of the golden coloured wrapper (above the weight).
Thanks to Correlux for the links.
Imgur compresses the images making them almost unreadable. Link in the pics.
When the OP stated “a deal” on those 26800, I was penchant to yet another hyped seller with fake cells. I’m always dubious of such claims. But after comparing the specs, they may be legit. As stated, would have to buy and test, and if someone else would chime in to cover some costs (or perhaps CollectEverything has a need for 20 units?), this may be an outlet for these batteries.
Edit:
I should give more credit to Correlux as he is more fact-checker and thorough than I.
I inquired about the shipping cost and was told $54 USD to ship an order of 10 pieces, shipping time ~13 days. That brings the total up to $80.4 before taxes or any other fees have been considered. I’d say $8 each isn’t too bad but I don’t actually need 10 of these for myself. I’m also unsure if I would have any import fees to deal with.
The ML cells can be recharged - if you try to recharge the CRs they’re likely to explode. And that’s the real meaning of primary vs secondary cells: primaries are disposable and secondaries are rechargeable.
There is also likely to be a voltage difference, which could harm things.
I exchanged a couple of emails with Aloft Hobbies about the QB 26800 cells. They don’t know who the manufacturer is, either, and their supplier isn’t talking. lol. So…may remain an eternal mystery. They are due to receive another shipment of 26800 cells in the next week or so, so that’s good news. May be worth comparing their landed/shipped cost with your source now. I’d email them to ask about shipping, though, because apparently their website software tends to go exorbitant for int’l shipments but they can do it cheaper.
Cheap for me so far. Last order was in October for two 21700 and it was $5.25. First time with 4x26800 and one 21700 it was $10.85. When I order from Illumn, Liion, or IMR it seems like it’s never less than $8-10 if any cell is involved, no matter the weight…they do accessories-only for a bit cheaper.
That said, the post office has increased prices a bit and I see that Aloft’s prices on cells have gone up recently as well…could be that shipping has followed suit, just have to plug in an order and see I guess. If it seems too high I wouldn’t hesitate to email them. Their shipping was ridiculously fast for the postal service, too, each time.
