Interested.
Interested by 2
Basically Nightwatch UI are same
Low-medium-High
Two click turbo
Three click Strobe
Other, f**k off
I like it but for more 10.000 lumens that can be an issu
Interested
Interested. Thanks.
Iāve check the specs on nealsgadget
āModes: M-L-M-H,triple clicks turboā
Classic, donāt write but think two click turbo
Brand:NIGHTWATCH
Model: NS59v1
LED: 9xSFQ55 5700k
Max output: 28,000lm
Battery: unprotected 2x 21700 button top (NS73V1 need to use the battery current 40A)
Lens: Glass with anti-reļ¬ective coating
Body: Aluminum with Type III hard-coat anodizing
Swtich: Tail switch
Weight: 338g without cells
Dimensions: 58mm head x215mm length
Function: 1. Reverse polarity protection
2.Temperature control
3.low voltage warn
Iām interresting , what they call unprotected 21700 button top
Interested.
Waiting to see more specsā¦
Extremely interested, however....
I felt exactly the same about the Nightwatch NS73V1, the triple SFN55.2 light, and as a long time loyal Nealsgadgets.com customer was hugely disappointed to be thwarted by the stinging **SOLD OUT** message for the NS59V1 moments ago on Neal's site exactly when I wanted to pull the trigger (arrrrrgh!) and BUY NOW.
Same thing happened with the NS73V1. SOLD OUT many weeks (months?) ago when I rushed to get one, hoping stock might replenish, to no avail.... kept checking each week, email inquiry, to no avail. I still really want one... quite saddened he never obtained more. I fear this might be the case with this new light .... unobtanium.
Please Neal, I'd buy them both in a heartbeat if you could obtain more.
Looks insane. Interested
Interested
For that kind of current it has to be e-switch. Clickies wonāt hold up
Looks truly nuts, Iām very interested
Iām in.
Interested
SOLD OUT AT NEALSGADGETS.COM
would love to buy one....
Interestd
List updated.
Interested, even if its 18-20k lumens it would still be a good buy. It could maybe make more considering it should be much more efficient than the Nightwatch NSX3 using 6v LEDs plus more LEDs should make it more efficient. 3amp at 6v yields 2200 lumens from this LED?
Interested
Interested as well
Interested. Thanks.
