hello, this week, you can use PC to click this link to get a 5 USD coupon for ordering RD6024: https://rdtech.aliexpress.com/store/selected-sale-items/923042.html?es=0zoEZ8%2F9sMa1O%2FL%2BIxBDcRoryit2GsPS
RD6006W feedback
The RD6006W module is very interesting, it met my needs. It is easy to operate and the real-time graph of current, voltage and power helps a lot to analyze some boards. The current limiting is also nice, works well.
https://www.aliexpress.com/item/4000282551930.html
RD6012P feedback
Great power supply. It will accompany it for the next few years of maintenance career. Perfect.
https://www.aliexpress.com/item/1005003472332331.html
DPH5005 feedback
device very well made, beautiful and accurate. Controls are easy to configure. Super recommended!
https://www.aliexpress.com/item/32840324731.html
RD6012 feedback
Not bad. This is a pulse generator, the output noise is acceptable, about 30 mV and bursts up to 100. I use transformer power. functionality is more than great. as an additional power supply is very good.I recommend to buy.
https://www.aliexpress.com/item/4001053200176.html
RD6024 feedback
Packaging is excellent, everything works. Thanks.
RD6012 feedback
I have made the box with wood, and I have put a toroidal transformer on it, everything is perfect!
(note:you must add rectifier and filter, DC output voltage without load should be lower than 65V)
share 2 great introduction videos about RD6018 and RD6012
www.youtube.com/embed/PNmXAyzWEK8
RD6024 feedback
very good product. Easy installation. Good communication with seller. strogly recommended
https://www.aliexpress.com/item/1005003744641750.html
hello, it is good to see that different customers has different thoughts to make the DIY power supplies based on our models, and welcome to send us more about it, if there is question when using the products, just contact us for help.
RD6012W feedback
Delivered quickly within a week. No need to talk about the product.
RD6024 feedback
good accuracy
RD6018 feedback
Arrived in 6 days! it works fine
https://www.aliexpress.com/item/1005001488070904.html
Although it is said many times, we still want to remind you that for our RD power supply, if you use switching power supply, it is recommended to use ours or other big brand PSU, for ours, we test, for big brand, they have quality control, for others, we dont know their quality
RD6012W feedback
Packaging and product quality are all good
RD6006P feedback
Recommend!
www.aliexpress.com/item/1005002185722889.html
RD6012P feedback
amazing!!! the best power supply ever!
hello, for output cables, we have 15A cable and 25A cable, you can choose the corresponding cable by the RD power supply output current, of course you can use your own cable, just make sure that the cable suppot the output current, otherwise it is not safe
https://www.aliexpress.com/item/1005003735954321.html
RD6012 feedback
The set I bought was assembled quickly when I got them, and the assembly instructions were very detailed, as well as the video. The test is done, it's very good
