you can remove me from the list:
post #312
added 02/15/2020
7 pcs.
many thanks for your continuous work
post #312
added 02/15/2020
7 pcs.
Can one of the beta testers confirm it still has the 1/4” tripod thread in the base? (given it looks so unstable)
No tripod mount on it. I asked Barry if it was going to be added but he hasn’t responded back.
What about a magnet in the base and head with a stability plate, stored on top of the head but moved under the base while in use to enlarge footprint.
The tripod mount threads would require the base to be much thicker, (thus making the mini taller) A magnet base would be the better option, for using a flat plate for added stability.
Interested in 1
I received the LT1-Mini test-unit today! I will be doing tests. photos, operational evaluations and a video over this week.
Cool, give us a small tease.
Yes!! A small tease please!!
> UPDATE,March,24,2022
Below is my initial tests of the Pro-production model along side of the IF25-based prototype: The Pre-production Sofirn BLF LT1M vs the LT1M Prototype!
> UPDATE,February,27,2022
Posted above!
I’m interested in one.
Put me down for two please. Thanks!
Additions to the interest list since post number 1407
Post# / Added / User Name
1436 / 03/21/2022 / LightAsFlash
1442 / 03/26/2022 / sHoRoMeM
1443 / 03/26/2022 / Sordoslux
Interested
I’m not even sure it’s A2. Maybe someone else knows?
Mine came with Anduril 2. Version check reports:
Programming pins are numbered - think match the pins of the processor:
The flashing pads appear to have the two columns reversed. So it says “1 2 3 4” on the pads for pins 8, 7, 6, and 5. And it says “8 7 6 5” on the pads for pins 1, 2, 3, and 4. Oops. Easy mistake to make though, and it doesn’t really hurt anything.
The unfortunate part is that the pads don’t follow the spacing used by BLF adapters like the HQ ProgKey, Lexel’s adapter, or Emisar’s flashing kit. And Sofirn doesn’t sell an adapter (yet). So I haven’t been able to flash it, since none of my adapters fit.
Here’s how it looks when trying to use a HQ ProgKey. I couldn’t get all the pads connected at the same time:
I think Sofirn might try to update their lights to use attiny1616 though, which would mean everything gets a new 3-pin flashing layout instead of the 6-pin or 8-pin layouts used in the past. The 3-pin design is already used on the SP10 Pro, and Sofirn is trying to put together a flashing kit for it. So I’m hoping the other models will get it too.
If that happens, I could also add thermal regulation… though it sounds like it’s not really necessary.
I think Sofirn might try to update their lights to use attiny1616 though, which would mean everything gets a new 3-pin flashing layout instead of the 6-pin or 8-pin layouts used in the past. The 3-pin design is already used on the SP10 Pro, and Sofirn is trying to put together a flashing kit for it. So I’m hoping the other models will get it too. If that happens, I could also add thermal regulation… though it sounds like it’s not really necessary.
Sofirn selling flashing kits? Advanced Thermal Regulation? Holy hell sign me up! Right NOW!
It’s not very advanced. It’s pretty primitive, really, and doesn’t have a name or even a classification other than “hacked together”. But it does generally keep things close to the target temperature, on a wide range of different hardware, without overshooting and oscillating the brightness.
… but from what I’ve heard, it’s probably unnecessary on the LT1-mini because it simply doesn’t run at high enough power levels for regulation to be needed.
Additions to the interest list since post number 1443
1445 / 03/27/2022 / SilentObserver
1447 / 03/28/2022 / zuluwalker
I saw this on Sofirn FB USA
LT1-Mini and C8L pre-production samples passed the test by LT1-Mini group team members.
