I’d vote for anduril 2 14500 only with RGB aux. usbc recharging is fine but not completely necessary. would love a single emitter and high efficiency driver as well. Maybe some knurling since it looks slippery as it is. Would def pay more for those options! Could be the light a lot of us are looking for!
I vote for Option 2 - AA-Support with Anduril2. No need for Charging (Option 4).
Option 3 14500 with auxiliaries. A future model WK11 can be a single emitter reflector light and AA compatible.
Wurkkos needs to get into the auxiliaries game! I am very excited to know you are thinking seriously about it.
Thanks!
Wurkkos the driver, mcpcb and optic would be very useful to sell as diy parts.
Also want to say we appreciate that you’re another company that engages with us directly and takes in suggestions
#3, no charging, regulated driver, spring loaded inner tube. A Noctigon KR3 .
Just my thoughts… :+1:
Option 3. No built in charging. Doesn’t have to be a triple, single would be fine. Anduril 2.
Either no aux leds, or RGB. I wouldn’t want a light with single color aux that I was stuck with. One of the things I really don’t like about the current Emisar lineup is the single color lighted switches.
Robust design if it uses an inner tube like the FW series. Mine never did work right, and it’s totally put me off of that design- even though I do find it aesthetically pleasing.
For me option 3 would be fine, although I’d prefer USB-C charging as well. And please multicolor AUX light (and programming pads )
YES. In the Emisar/Noctigon layout!
14500 with charging so it can be gifted
A good switching driver, Anduril2 and tail-switch will make this an absolute instant buy.
About option 2 vs 3… I don’t feel strongly either way. But for an efficient, 100% duty cycle boost driver: oh yes! make it as long as you need to! This will make the small battery last longer in lower modes.
About triple vs single LED, at 2A output there is over 20% gain in lumen from using 3 LEDs vs only 1,looking at some lm/A curves. Vf also stays a bit lower (good with a boost driver). But I would be happy with a single LED with a throwy TIR too.
Anduril is perfect for ramping, as well as managing heat and brightness (and everything else). Staying in simpleUI, or configuring it how you like and disable turbo (can now be done in the UI) for those that don’t want a hotrod or need to restrain themselves. 2A-3A should be fine with a 14500.
I want in on the first order please!
I would prefer option 3. Andúril 2 is a must.
Beyond that the following would be nice to have: deep carry one way clip (two way clips are awful), flashing pads and a firm switch with sufficiently high activation force (to prevent accidental activation).
It really depends on how you use your lights.
I typically use my lights at close range indoors. A tiny triple with a bright floody beam, like an FWAA, is vastly more useful for me than than a light with a relatively small but throwy hotspot.
And a bright Turbo allows for quick scans of a large area outdoors. I also don't use my compact EDCs on sustained High or Turbo for long, it's just not what they were designed for.
I vote #1 or #3, but am more interested in whether the TS21 will be “fixed,” as well as what a Wurkkos remix of the LT1 or LT1S might look like.
Unless Sofirn is keeping the lanterns for itself, I’d like to see what a more adventurous brand like Wurkkos would offer in that space.
thank you, we will try to do more
Please include a RGB auxiliary light please! This feature will set your little triple apart from all the rest. I will buy 1 maybe without, but with RGB’s I will buy many over time!!
I vote for #3. Make it long enough to accept a longer battery with a USB charge port built in to the battery. No charge port on the light. Anduril is a must for me. AA compatibility would make it versatile, but you can’t have it all apparently.
Option #3 here…
