14500 with charging so it can be gifted
A good switching driver, Anduril2 and tail-switch will make this an absolute instant buy.
About option 2 vs 3… I don’t feel strongly either way. But for an efficient, 100% duty cycle boost driver: oh yes! make it as long as you need to! This will make the small battery last longer in lower modes.
About triple vs single LED, at 2A output there is over 20% gain in lumen from using 3 LEDs vs only 1,looking at some lm/A curves. Vf also stays a bit lower (good with a boost driver). But I would be happy with a single LED with a throwy TIR too.
Anduril is perfect for ramping, as well as managing heat and brightness (and everything else). Staying in simpleUI, or configuring it how you like and disable turbo (can now be done in the UI) for those that don’t want a hotrod or need to restrain themselves. 2A-3A should be fine with a 14500.
I want in on the first order please!
I would prefer option 3. Andúril 2 is a must.
Beyond that the following would be nice to have: deep carry one way clip (two way clips are awful), flashing pads and a firm switch with sufficiently high activation force (to prevent accidental activation).
It really depends on how you use your lights.
I typically use my lights at close range indoors. A tiny triple with a bright floody beam, like an FWAA, is vastly more useful for me than than a light with a relatively small but throwy hotspot.
And a bright Turbo allows for quick scans of a large area outdoors. I also don't use my compact EDCs on sustained High or Turbo for long, it's just not what they were designed for.
I vote #1 or #3, but am more interested in whether the TS21 will be “fixed,” as well as what a Wurkkos remix of the LT1 or LT1S might look like.
Unless Sofirn is keeping the lanterns for itself, I’d like to see what a more adventurous brand like Wurkkos would offer in that space.
thank you, we will try to do more
Please include a RGB auxiliary light please! This feature will set your little triple apart from all the rest. I will buy 1 maybe without, but with RGB’s I will buy many over time!!
I vote for #3. Make it long enough to accept a longer battery with a USB charge port built in to the battery. No charge port on the light. Anduril is a must for me. AA compatibility would make it versatile, but you can’t have it all apparently.
Option #3 here…
I’d favor #2, but no charging port and no aux lights. Please design with a straight tube. Efficiency is the main thing. Anduril is good, though I’d be fine with Narsil.
14500, anduril 2 with the aux RGB single in the center and a screwed on clip rather that the loose clip please
Option 3 with 14500 and RGB aux lights. Having onboard USBc charging would be nice to have as to differentiate from other 14500 lights on the market, but not if it makes it as long as the 18650 lights
Some other general thoughts:
Driver: I don’t know how possible it is at this stage, but a driver with a regulated, flat output would be fantastic and would really elevate this light into a must have. From my experience owning an FWAA, an efficient driver is preferable in a light of this size. The FWAA is inefficient with its FET+1 7315 driver and it has poor battery life at any level above the regulated 350mAh.
Regulated and good efficiency is a must for me. That’s why I love the most recent series of Fireflies flashlights that use the LUME driver. I use them almost everyday for work and as ceiling bounce lights. But FF stopped producing the LUME driver due to chip shortage for over a year already. I also love Olight flashlights because they are soooo efficient and have the best regulation despite they only come in CW low CRI.
I have almost a dozen Lumintop FW flashlights but I hardly ever use them because of the poor regulation and poor efficiency. They are simply toys unlike the FF lights that are actually usable for work purposes.
USB-C would make the lights giftable.
Also please have a Nichia 519A 9080 option. These new emitters are brighter, more efficient, and better tint vs the SST-20 95CRI.
I’m hunting something with that LUME driver for the reasons you said. I really want to try it.
#3. Rgb aux, captive deep carry clip.
Charging isn’t a priority for me.
More Body colors, I would love some colors like my ts21
If we’re throwing crazy thoughts… special edition with some 519s
Decision has already been made.
- Keep this existing compact design use anduril 2.0 and aux lights but only work with 14500
we will go ahead with option 3 and will assemble prototype with single color aux and test it
thank you for all ,In order to advance the project faster, we will probabile choosing option 3 and completing the prototype (with single aux )assembly this week
I look forward to seeing it! It’s impossible to satisfy everyone, but I think this will make a lot of people happy and deliver a small, relatively inexpensive, feature rich, high performance flashlight.
Any rough idea of when the WK10 is planned to be released?
