Awesome, thanks gchart. Cant wait to make a start on this!
Would anyone be able to suggest an alternative Super Barrier rectifier to the one suggested (SBRT05U20S3)?
I am having trouble tracking on down on digikey.
Thanks
I donāt think the particular diode is critical as long as itās the SOD-323 footprint. The BAT54 is pretty common and cheap.
Anyway, that reminds me.
I still have a lot of these, and since Iām getting some new soldering equipment pretty soon, I could make some very low resistance switches
I do have the issue of the components being a bit problematic to source however.
@gchart, do you know where to get supercaps? I can find all other components still available obviously, but not the supercap.
I found it!
That means I can still build it
Itās also cheaper than when I looked last time, which is surprising.
The super capacitor will provide ~20 uAh to 2 volts so it will likely keep the board functional for a few hours. Then what happens? The light may no longer be operational for a while after that.
@hoop, Iām building the GFS16 without the LED board, so once the supercap is fully charged, itāll stay charged for a long time.
@BlueSwordM color me interested, Iād be down for a couple if you make some, missed out the last time you offered to do some up.
@darkshot, no problem.
Now that I have a competent soldering iron again, Iāll finally be able to do some stuff
@BlueSwordM, Id also be interested in buying a few if you make them. Is it possible to makethem with the LED board also?
@JS93, not with the current boards I have.
I only have the low resistance switches.
Iāll first buy the components for the 10x switches I have, and fulfill the āreserveā list first, and then sell the rest.
If everything goes well, Iāll just order 100x for components and do a small GB for components, and completed switches
So, Iāll order the components after my exams.
If I can build one well enough, Iāll start making them myself and then shipping them.
If not, Iāll just sell the components directly to you, my friends
1. Darkshot
2. Darkshot
3. Inkidu
4. Shirnask
5. TomE
6. TomE
7. Kawiboy1428
8. Kawiboy1428
9. MRsDNF
10. MRsDNF
11. Inkidu
Is this list still valid?
still in
Nice, not everybody is dead it seems.
I now have 2 slots left since I donāt really care too much about these switches anymore.
Iāll take āem.
Well, since my XHP50.3 HI GB went to water, I guess Iāll do this first
Iāve decided it: I will commit to this project entirely by buying a high current switch light with the Convoy M21B to see how large of a difference it truly makes
Anyway, Iām planning to end my projects from ascending order, so Iām likely to make a thread detailing everything that Iāll be doing.
These things wonāt be coming by themselves otherwise
