IMALENT MS12 MINI new products for sale!!!
Noisy like the 100,000 Lumen monster ?
Regards Xandre
Are the fans automatic and heat activated like the MS18 or do they have the button to activate like the MS08? Those always get activated accidentally
When will the XHP70.3 available?
Hey what’s the difference between the .2 and .3?
XHP70.2 is HD and XHP70.3 HI
70.2 more lumens output and 70.3 farther throw.
Another question. Is this MS12 mini first batch available in 5000k or 6500k?
Nice thanks for the info! Which one are you getting? That’s a tough choice… I have the MS08 and I do wish it would throw farther
What I understand only the 70.2 is available for now. I believe I will take the 70.2. Close to 10 000 more lumens output.
Per the email I received from Neals, the batch that’s available now is in 6,500K …
Just ordered mine because Neals has it at 25% off during their
April Deals sale. Total price with priority mail was $313. Too good to pass up.
Coupon - ND25F
I'm currently testing the XHP70.2 version, and at turn on it can even reach a little above 65,000 lumens. Dropping to below 50K in 30 seconds...
Fans are noisy
Mine is around 5500K in Low and Mid1..
(charging the battery at the moment, so can't measure cct in turbo)
Review should be ready on 1lumen.com in about a week or 2
The MS12 mini is delivered yesterday to me from Neal.
I see that there is a AC/DC adapter of 19V /2A,which is small.I have a larger 19V/4A charger,but when I measured it with a meter,I saw 19.9V,while the small is 19.16V.
Is it good for the light to use the large charger instead of the small one?
I see from the other hand in the manual,that the charger included,is (19-24)V.
So,I think that the larger will be OK.
Any suggestion please?
Using a different charger is something I would do but not recommended others do :smiley:
It could void the warranty if you’re unlucky.
The charging circuit should be fine with a small change in input voltage.
I am considering ordering a USB-C PD to DC barrel adapter like https://www.ebay.co.uk/itm/125301652813 (haven’t checked the size yet).
