Is the body going to be available in colors other than black and if so what colors? And will the aux be dimmable? Those will help us decide, thank you!
It’s not Lumintop, that’s enough justification imho. I own flashlights of both brands and definitely have a preference (non technical/design reasons). But I do hope this one gets a decent driver, that would be an big improvement.
Option 3 IMO. I would definitely pay a little more to have anduril and good CRI/temperature. I also don’t really think it needs an integrated charger but I will say please make sure it has a good button. I have an FW1A that is totally useless because the button is so bad. It worked for about 3 days and then completely stopped working unless I press the button really hard and even then its only like 50/50 on if it registers a press.
The first post suggested $15.99 might be achievable for price. That sounds like a challenging price to achieve, but if it is anywhere close to that price, it will be significantly cheaper than the FWAA.
I did not see the driver architecture mentioned. The FWAA driver has 1x7135 chip + a FET channel, which seems reasonable for the size of the light. If there was any question about including the 7135 channel or keeping the cost lower, I would say the 7135 channel should be a very modest cost that is well worth the regulation and slightly better efficiency it enables at lower levels, compared to a light that runs only on a FET channel.
