Selection of "slender waist" Wurkkos WK10 14500 Light Single Color Aux
Me too. You have very good Taste… LOL
Oh they look great so far. Very excited about these!
That purp tho!
is there any significant change in parasitic drain (there should be)
I voted green, though I won't be buying the flashlight.
Looks like I'm in the minority with my color choice...
It's not easy being green.
Main thing the Aux should have is the ability to set them to high, low or off inside Anduril2.
My Emisar D4V2 lights look beautiful with full brightness on Aux, but I find that to be impractical. They are bright enough to light up my room at night and have significant parastic drain. On the other hand, the low brightness aux LED setting is perfect. Just bright enough to easily find the light when used as a bedside light.
This is a standard feature on anduril 2 I believe...
Voted ice blue to prevent red (best chance). All colors except primary colors R, G, and B are good.
You guys have to remember that this light is aimed at around 20USD.
RGB aux cost more and need more space. RGB literally means 3x LED and resistors and what not on the board to make them work.
You have to frankly come to terms with the fact that because of cost and space issues Wurkkos will most likely just produce one AUX colour for the whole batch. So choose wisely :stuck_out_tongue:
good ideal for different aux colors with different tint choice, collect
Yes, our budget is $20, and single aux led seems the only option now, we will not only do one color, maybe 3-4 different
I doubt it would make much difference in cost really.
And I would guess that managing several SKUs would actually cost more.
Is the reason because you’re using a SOIC-8 Attiny85 ? (not enough pins for FET+7135 and RGB), if that’s the case then use a QFN-20 package, or you could even go Attiny1616 which has several advantages : it’s cheaper, has a factory calibrated temperature sensor, UDPI (only 3 pads needed for flashing, especially practical in the case of a small diameter driver here) and plenty enough pins for RGB. Sofirn sourced them for the SP10S Pro so I assume that wurkkos can too.
I think they are implemented as functions on andruil?
Is the reason because you’re using a SOIC-8 Atinny85 ? (not enough pins for FET+7135 and RGB), if that’s the case then use a QFN-20 package, or you could even go Attiny1616 which has several advantages : it’s cheaper, has a factory calibrated temperature sensor, UDPI (only 3 pads needed for flashing, especially practical in the case of a small diameter driver here) and plenty enough pins for RGB. Sofirn sourced them for the SP10S Pro so I assume that wurkkos can too.
[/quote]
yes, attiny1616 will be our choice
Ahaha, I’m a bit suspect, you know? :smiley:
That’s good to hear, but what is the limitation for RGB then ?
I’d love to see multiple colours available like in the original run of the E07. I think they had red, ice blue, purple and yellow? Something like that would be excellent. More often than not I’d prefer one colour rather than loads to choose from. I only mess around with my D4V2’s aux lights (and previously D4SV2’s) because they’re there. If they weren’t it wouldn’t be a big deal, ya know?
I imagine soldering the wires costs money. Three times the chance to mess it up.
The $20 budget seems tight.
I chose YELLOW, though all of them look great. except Ice Blue, i am just not a fan. too bright not saturated enough.
I would be happy with Yellow, Orange, Red, or Blue / Purple.
through a couple of new FireFlies i have received, i honestly would rather have a nicely colored single aux more than RGB. I have gotten orange and yellow recently and they look MUCH better than the "orange" of any of my RGB setups, giving the light a more customized feel and look!
thats just my opinion!
Orange
purple and Orange
orange and yellow
Purple, pirple, perple
