I do like a good clip. I’m usually grabbing an Olight M2R, S2R2, or M1T PLUS clip and throwing it on a light that I prefer more. With this WK10 I figured I’d just find a clip I like more if I didn’t like him. I don’t even much thought anymore.
But I mean, yeah… If we can get better clips right out the gate that would be awesome. Especially when the 21700 version comes out. That would be a bit larger and a solid deep carry clip would be a brilliant thing to start thinking about now.
My thought’s exactly. I’m dying for the FWxx Lume1 drivers to make a return. I want to make my FW series lights more useful. Also eyeing up the SP33S and SP35 from Sofirn solely because of their superior drivers and runtimes. I’ve got enough FET toys for now
Does the aux light have extreme low power drain (in low brightness mode) ?
For me the purpose of aux light is to find the flashlight in a dark room - eg in a power-cut. However if it drains a battery in a few days/weeks then it is pointless.
Low drain for aux light - and also parasitic drain in general - is particularly important with a small cell like 14500
Low AUX mode with anduril uses the internal pull up resistors, which is 35K for the Attiny1616, that means that the maximum current on low (ignoring the series resistor) with a blue or green led is ~50uA, about 30uA in average. ~70uA max for red, 50uA in average. This is pretty low, more than 2 years with a 1000mAh cell and a red AUX LED on low.
I agree that low-drain for aux is important, but let's not forget that with Anduril, we can turn down the brightness (not ideal for us aux fan :-) ) Maybe by default, aux should be set in the beacon mode and not set to constant on?
I read a ton of answers looking for someone that say this. 100% agree. 3 leds in a 21mm lens will be TOO floody. I have an old Olight s2a baton (with a slighty wider diameter of head) and lower output (around 500lm), and the big hotspot is really useful. It would be interesting a 14500 with 800/1000lm with either 1 led with big hotspot or 1 led with small hostpot and more throw. It might be also possible to offer both options.
In both cases will be more useful than almost pure flood that will give the triple lens in such a small diameter.
