Selection of "slender waist" Wurkkos WK10 14500 Light Single Color Aux
Yes, our budget is $20, and single aux led seems the only option now, we will not only do one color, maybe 3-4 different
I doubt it would make much difference in cost really.
And I would guess that managing several SKUs would actually cost more.
Is the reason because you’re using a SOIC-8 Attiny85 ? (not enough pins for FET+7135 and RGB), if that’s the case then use a QFN-20 package, or you could even go Attiny1616 which has several advantages : it’s cheaper, has a factory calibrated temperature sensor, UDPI (only 3 pads needed for flashing, especially practical in the case of a small diameter driver here) and plenty enough pins for RGB. Sofirn sourced them for the SP10S Pro so I assume that wurkkos can too.
I think they are implemented as functions on andruil?
Is the reason because you’re using a SOIC-8 Atinny85 ? (not enough pins for FET+7135 and RGB), if that’s the case then use a QFN-20 package, or you could even go Attiny1616 which has several advantages : it’s cheaper, has a factory calibrated temperature sensor, UDPI (only 3 pads needed for flashing, especially practical in the case of a small diameter driver here) and plenty enough pins for RGB. Sofirn sourced them for the SP10S Pro so I assume that wurkkos can too.
[/quote]
yes, attiny1616 will be our choice
Ahaha, I’m a bit suspect, you know? :smiley:
That’s good to hear, but what is the limitation for RGB then ?
I’d love to see multiple colours available like in the original run of the E07. I think they had red, ice blue, purple and yellow? Something like that would be excellent. More often than not I’d prefer one colour rather than loads to choose from. I only mess around with my D4V2’s aux lights (and previously D4SV2’s) because they’re there. If they weren’t it wouldn’t be a big deal, ya know?
I imagine soldering the wires costs money. Three times the chance to mess it up.
The $20 budget seems tight.
I chose YELLOW, though all of them look great. except Ice Blue, i am just not a fan. too bright not saturated enough.
I would be happy with Yellow, Orange, Red, or Blue / Purple.
through a couple of new FireFlies i have received, i honestly would rather have a nicely colored single aux more than RGB. I have gotten orange and yellow recently and they look MUCH better than the "orange" of any of my RGB setups, giving the light a more customized feel and look!
thats just my opinion!
Orange
purple and Orange
orange and yellow
Purple, pirple, perple
I reeeally dig purple!
But I think I read something somewhere recently that purple aux lights have the worse parasitic drain?
It's the worst on your eyes and the least efficient...but certainly the most beautiful.
I diddnt know it would be bad for your eyes.
You mean for retaining night vision?
I thought it might be better than red for that.
If you were to look directly at the aux lights in total darkness I mean.
Its not like its an actual UV light is it?
Iv read here that UV lights are not great for your eyes.
I appreciate aux lighting being added on more lights and as such appreciate Wurkkos adding aux light. However, in my particular case I have no interest in 14500 lights. Are there plans to add aux lighting to more of your larger lights?
I'm so excited. This is the best idea for a light design yet! I'm buying one of each color!
Same.
Id be all over a TS21 with Aux!!!
Then I can finally have my “dummy proof emisar.”
I voted orange. I see orange and red are doing well so we should combine those into amber color and stomp on ice blue.
I voted red, all of my Hank lights that get deep of night use are set on red as it is the least likely to disturb sleep or getting to sleep on low. I really love purple and dark blue, but blues cause me difficultly going to sleep.
yes, we are planing on a 21700 version in near future
Me Too!
