Thank you for your support!
Hi Freeme, do you have any idea when these are supposed to start shipping out?
Iām wondering the same thing
I just got a shipment notification, so my label has been generated at least.
Thanks for your reply
Visibly issu with black alu bezel , they canāt ship order
Iāve contact them and change order for steel bezel
Iāve now tracking order
Wait there is a problem with the black bezels?
Except for the fact that he doesnāt have them in stock, no.
Just they wait to receiv it for ship order, I think.
Even if sometimes he never says anything and your order can wait weeks
Well looks like I need to contact themā¦.
Hug
Contact them with chatbot bottom right on nealsgadget website
Choose āinformation orderā or something like that
Enter your order ID receiv and your mail use for the order
After the bot tell you āorder XXXX is awaiting fulfillment.ā
tell āany shipping date?ā and a guy respond to you normaly, after itās an negociation
Well, that was pretty painless. The whole process to no more than 5 minsā¦ā¦ Neals Gadgets on r/flashlights doesnāt have a great reputation for getting back to customers or being generally responsive. However, this was greatā¦. pretty happy with the customer serviceā¦.
FYI: The first batch is just SS bezelā¦. The aluminum bezel will ship out on the 12th
Any one got one, how many amps is it doing?
Definitely interested to see how the numbers match upā¦
Received mine today. Reverse clicky mechanical switch. 20,000lm @turn-on with two P42Aās. Body tube comes in half for use with one cell, but it wonāt actually turn on with one cell. Bezel says āCHAOSā on it.
Yea about what i guessed maybe 22000 lumens is possible by lowering resistance if it can be lowered.
You make me dreams. If you have picture for tonight
Mine come tomorrow
They recycling body tube, just they add extension for this light I presume.
Nealās UI description is slightly incorrect.
There are 4 normal modes (āMoonlightā, Low, Medium, and High. They are memorized and a half-press cycles to the next mode.
Turbo is accessed by a quick double-half-press from on. A click then quick half-press from off works too.
Strobe is accessed by a quick triple-half-press from on. A click then a quick double-half-press from off works too.
The mode spacing stinks but I will rarely be using this on any mode except Turbo.
Normaly if you turn off a high, if you turn on you start at low, at each start they up one step O_0.
itās that to all my Nightwatch light.
You take quickly double short press for turbo at each start
Even if for me the most usable modes is High for Nightwatch
Nice. I was hoping for more. Maybe try some 30Ts in it. Hopefully Neal will send one for testingā¦he promised but weāll see. Nightwatch UIs are nothing to write home about. No surprises there. I wonder why it wonāt turn on with one cell?
I will try and review mine when I get it. It should in theory be able to do more than 20k lumens but in a 2 series light it will be hard as you are limited to the current output of one cell plus there are not to many high amperage 6v drivers. 3-4 cells in parallel would have been better, still this light is doing 100+ watts no slouch.
I have some P42A cells and they are top tier.
Iām assuming it has LVP, so one cell would be well below the LVP cutoff. I imagine thatās why itās not turning on with one cell.
If anyone makes some 40A 21350ās theyāll work like a charm, haha.
