Cool MascaratumB!
I think I’m gonna try that switch mod.
Last night my 14500 battery suddenly depleted.
Quick voltage check using Nitecore F1 charger shows only 2 volts but my VC2 charger says the battery is full
It makes my FWAA is practically not in use until I get a new battery. It’s not easy to find good one here locally.
Ha! This is a very nice find, I wonder how come I've skipped over it until now..
Anyways, I believe the proper fit should be for the tail switch versions, MT20C or MT10C:
Also, while not a straight fit, I've found that a C8 Mini version (Jaxman in this case - not all C8 minis might fit tho I suppose) with the need of a conductive ring/spacer would be a better proportioned fit with its thinner tube and tailcap.
I’m not sure how common these tins are around the world, but the plastic lid of my Lavazza coffee tins are a perfect fit as a protective cap for the Wildtrail WT90. But although it clamps, I will use two bits of cellotape as well because the WT90 bezel has no rim around the outside of the bezel for a firm clamping action, like the coffee tin.
Does anyone know if there are 18350 tubes for the S6? I clicked the link that edeekeos posted in this thread but it looks like the black tubes are no longer being produced. There are silver versions available but I would prefer the black.
There seems to be identical items on AliExpress but the seller ratings are pretty poor so I would like to avoid going that route and avoid the headache, even if it’s just items which are a few dollars.
Are there any other options I can look to for an 18350 tube for the Convoy S6?
If not, I guess I might try my luck on the silver tubes on Banggood…
Sofirn LT1 Mini & Sofirn C8L’s tailcaps can be swapped.
LT1 Mini’s tailcap on C8L requires the tailcap to be loosened/tightened to turn the light on/off. I suppose it does allow tailstanding though, which is an improvement.
The C8L tailcap on LT1 Mini prevents tailstanding because the button protrudes, and Anduril does not turn on automatically when connected to power so the switch just serves as a mechanical lockout.
Hi guys, I messaged Simon to check if the S2+ 18350 tubes work with the S6 and they do! He said to use the new square or rectangular cut threads. The previous trapezoidal threaded tubes don’t work but the ‘newer’ ones do.
Here is the S6 with shorty tube next to a regular-sized S2+
I can confirm the fit is correct and it works perfectly! I’m very pleased.
It is a clone of a Thyrm Switchback 2.0. The quality is not quite as good as a real one but I have both and the clone is still plenty good, especially for the price of less than $2.50.
