More New Cree Goodness coming....
214 posts / 0 new
raccoon city
raccoon city's picture
Last seen: 47 min ago
Location: Palm Desert CA ~ West Coast is the best coast
Mark M wrote:
A few high CRI 5000k XHP 70.3 HI in-stock at cutter
Sweet!
It'll be nice when something like these make their way into mass-produced flashlights.  :THUMBS-UP:
Azirine
Last seen: 1 day 7 hours ago
raccoon city wrote:
Sweet!
It’ll be nice when something like these make their way into mass-produced flashlights.  alt=:" />
How does this compare to GT-FC40?
Mark M
Mark M's picture
Last seen: 3 weeks 5 days ago
The 70.3 HI should be able to handle more current. They will probably be close in performance.
Bob_McBob
Last seen: 4 hours 15 min ago
I bet that will be pretty green based on the EasyWhite binning.
AlexGT
AlexGT's picture
Last seen: 8 hours 56 min ago
Kaidomain has XHP-70.3 HI in 3000, 4000, 5000 and 6500k temperatures, what do you all think about the bins?
http://kaidomain.com/search&search=Cree%20XHP70.3
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 18 min ago
They seem great Smile
Mark M
Mark M's picture
You’re probably correct. The bin code is 50G x=0.3447 y= 0.3553 duv looks to be slightly negative. But it’s a 3 step ellipse so a lot of variation is possible there. I have 8 of them on the way so I’ll let you know.
Mark M
Mark M's picture
LunaLoves
Last seen: 4 min 30 sec ago
I was very excited about those till I looked into the datasheet and they basically look identically to the 50.2 3V
Mark M
Mark M's picture
I didn’t look, and yes you are correct…
thefreeman
thefreeman's picture
Last seen: 3 min 4 sec ago
Mouser has them too , but yeah still cool white low CRI, sliced they could get closer to neutral white, and HI.
elendur
Last seen: 1 month 4 days ago
Great info, thanks all! I ordered a couple of xhp50.3 hi variants from kaidomain (90 cri 2700k and 5000k, and 80cri 4000k).
So what kind of currents can these handle? 18W in the 6V configuration (with a convoy 20mm xhp50.2 driver) seems like babying it. Hank’s b35am dm11 driver seems to give around 22W (6A measured at tailcap): that better. How about feeding it 30W?
I might have to plug one on one of my cheap variable buck drivers and visually gauge the point of visually diminishing returns.
BlueSwordM
Take what the XHP50.2 can handle, and use that as your guide.
elendur
Thank you. I was wondering if being domeless made a difference. Also, it also apparently has improved thermal conductivity, so the efficiency curve could could be a bit higher.
In any case, going off the 50.2 tests, it seems like 18W and 22W are reasonable.
Haukkeli
Last seen: 10 min 23 sec ago
Green AR coating is really effective for lowering the duv. XHP70.3 Hi 5000K 80cri from Kaidomain went from 0.0028 with purple AR coating to 0.0000 with green AR coating. No further modifications needed. Flashlight was Convoy M21B.
Ryzbor
Ryzbor's picture
Last seen: 19 hours 23 min ago
Haukkeli wrote:
(…) XHP70.3 Hi 5000K 80cri from Kaidomain went from 0.0028 with purple AR coating to 0.0000 with green AR coating. (…) Flashlight was Convoy M21B.
Nice. At which mode did you get the 0,0000 duv value? And is there a donut hole in the beam?
Haukkeli
If I used 5 modes option in 12 group driver, mode 3 was 0.0001 and mode 4 0.0000. No donut hole thankfully. It seems I had a problem with reflow. Not all dies lit evenly.
Azirine
Anyone tried the XHP70.3 HI 90 CRI? How’s the duv?
Bob_McBob
I’m interested in how these ended up performing. The two similarly-binned HIs at Kaidomain are too green for me to use.
Haukkeli
I have on 50G in M21B and with old AR coating it was greenish, with new AR coating it is neutral. DUV 0.0002
Bob_McBob
My second order of 4500K XHP50.3 HI from Mouser is unfortunately greener than the first, right at the edge of too green to use. 0.0033 in my test setup and a little lower in a light.
Gyronamics
Last seen: 3 months 4 days ago
Got a couple of 4000k 70.3 90cri from kaidomain off aliexpress
Installed one safely in a dive torch and its exactly like turning on a household light.
Then I had to transfer the other to a specific pcb and I’m pretty sure I roasted it and it popped during electrical testing.
Now to consider buying more leds and upgrading my soldering and lack-of-real-hotplate situation.
welight
welight's picture
Last seen: 3 weeks 4 days ago
newly released Element Cree XEG
Cutter Electronics Pty Ltd
Web: https://www.cutter.com.au
Hoop
Hoop's picture
Last seen: 16 min 40 sec ago
Did you center the die on the MCPCB? Why are there gaps in the copper around the solder pads?
g_damian
g_damian's picture
Last seen: 10 hours 38 min ago
I installed and measured XHP50.3 HD (sliced) 80 CRI 4500K and XHP50.3 HI 90 CRI 4500K from mouser.
details in this post
M.Dickie
Last seen: 1 month 1 day ago
I’ve been using a 3v 50.3 lately and thought I would try slicing the dome out of curiosity. Lowered the CCT from 5800 to 5000. The CRI went down (70 to 67) and the DUV went up (from 0.0021 to 0.0081).
It’s much less visually appealing now. More yellow/green. Oh well.
QReciprocity42
Last seen: 1 day 2 hours ago
M.Dickie wrote:
I've been using a 3v 50.3 lately and thought I would try slicing the dome out of curiosity. Lowered the CCT from 5800 to 5000. The CRI went down (70 to 67) and the DUV went up (from 0.0021 to 0.0081). It's much less visually appealing now. More yellow/green. Oh well.
This is extremely surprising to me! Generally the green goes down when you slice, it doesn't quadruple! Got any pictures?
M.Dickie
QReciprocity42 wrote:
M.Dickie wrote:
I’ve been using a 3v 50.3 lately and thought I would try slicing the dome out of curiosity. Lowered the CCT from 5800 to 5000. The CRI went down (70 to 67) and the DUV went up (from 0.0021 to 0.0081). It’s much less visually appealing now. More yellow/green. Oh well.
This is extremely surprising to me! Generally the green goes down when you slice, it doesn’t quadruple! Got any pictures?
Indeed! I have a couple more on the way to retest. I’ll get picture this time around.
One thing I noticed while slicing the dome was the dome itself looked different than most emitter domes I’ve encountered. It almost had a refractive quality to it. Unfortunately it went flying across the shop into the abyss. Oh well. I’ll document it all with the next emitter I recieve.
QReciprocity42
I would absolutely love to see the pictures from your next test! Hopefully they will demonstrate the refractive quality you described.
The only negative dedome experience I've had was 3V XHP50.2, which turned green after dedome. It is not surprising to me because the phosphor pour is very different and extends way past the underlying blue chips, so any theory about dedoming a typical emitter (phosphor exactly over blue chip) goes out the window. Dicing it up (removing the excess phosphor past the blue chips) removed the green.
Your case surprises me because as far as I can tell, with the 3rd gen XHPs, the phosphor pour is exactly over the blue chips and does not extend beyond, so the phenomenon I described with the XHP50.2 should not be happening.
MoreHiCRILumens
MoreHiCRILumens's picture
Last seen: 35 min 9 sec ago
I got 3V sliced XHP50.2 in my Nitecore HC30. It’s green and ugly yes. I think it was 5700k:
You know which is it. Then 219b sw45k and TS10 6000k.
I don’t know if green filter would help? I kinda like that yellow, but that green in that is just too much.
