The There Are No Stupid Questions Thread
1858 posts / 0 new
CRC2
Last seen: 1 week 1 day ago
@Correllux
Thank you very much!
This is a lot of good information for me to work with.
All very helpful to me right now.
CRC2 wrote:
https://www.aliexpress.com/item/1005002639038647.html?spm=a2g0o.store_pc...
Is this a “boost” driver?
Correllux wrote:
As for the driver in your light, he says down the page that is has a max of 4.8 amps (4800mA)
Is it a boost driver though?
Im wondering what makes it different than the “regular” convoy drivers.
Its “designed specifically for the 12v GTFC40 LED.”
So is it “boosting” the Cells power to meet the LEDs requirements?
Im mostly just wondering if its a “better” driver?
Boost is supposed to be more efficient right?
Its not critical informaion I need. Just curious and trying to learn.
Correllux
Correllux's picture
Last seen: 1 day 1 hour ago
Yes. A magic one.
He gives the numbers that help you know….Input and Output.
Input is 3 to 4.2 volts, which is what’s normal for a single lithium-ion cell.
Output is boosted alllll the way up to 12 volts! Woohoo! And at that voltage has a current of 2.5 amps.
I’ve always thought boosting was a little magical. It’s easy to grasp the idea of a buck driver, where “extra” voltage is just diverted and wasted as heat…like flattening a heaping scoop of coffee grounds (which is sinful). But making more out of less is pretty special…especially when bumping it up to 12 volts instead of the much more common 6 volt boost needs. This is chosen by the particular emitter, of course.
If you look at the photo of the top side of the driver, that big grey square is an inductor, and that along with some other components is making it all happen. Some inductors look like little black cylinders, maybe with a black shrink wrap around them or maybe without, allowing bare copper wire winding to be visible…and some look like little glittery charcoal briquettes…lots of different types of inductors and they can be used for both buck and boost purposes (either/or, or both at the same time, depending on the circuit design).
Now on the flip side, take a look at this one from him…it’s a buck driver but it looks very much alike: https://www.aliexpress.com/item/4000372903914.html
That one tells you that the input is from 3 volts up to 8.4 volts, which would be the voltage of one single cell or two cells in series. Since normal 3v and 6v emitters will likely go poof if you press 8 volts into them from two batteries, this driver bucks off that extra higher voltage to regulate it into something that protects the emitter at a normal 3-4 volt range (the voltage an emitter uses is variable while in use and depending on current and binning, within a small range). Big fat square inductor but it’s being used for a different purpose here (it’s no doubt not the exact same spec inductor as on the other driver, but just as an example of the dual-purpose).
Here’s a pic of a different old-school kind of inductor, still popular in many designs and devices: https://www.aliexpress.com/item/32733255958.html
And an even older-schooler inductor with a fat iron donut wrapped with wire: https://www.aliexpress.com/item/32760098085.html
All this inducting business is the magic of magnetism, by the way…same as in A/C motors and many other electrical things. The energy in naturally produced magnetic forces is built up or torn down to different levels and used for world domination.
Sidney Stratton
Sidney Stratton's picture
Last seen: 3 months 1 day ago
Tidbit: Dr. Jones designation of Guppydrv & Moppydrv from the names of his cats. The ‘drv’ being shorthand for ‘driver’.
CRC2
Awesome!
Thanks again for all the information Magneto
CRC2
Aha, thanks
Correllux
Correllux's picture
Just saw your post…typing that long reply. lol. Different driver than what is in your C8 with the Osram…very different. Your Osram is a normal 3v emitter, so no special buck or boost needs there. However, in some more expensive/complex drivers (and lights) a buck/boost driver is used even for the 3v emitters just because they are more efficient and usually also because they can better regulate output for more consistent light in at least some modes. It’s all a balance…if you want consistent light then you have to work the magic because the power from the battery is not constant like from a/c power or if using a really giant battery with huge capacity. So if a fully charged cell is at 4.2 volts but your emitter only needs, say, 2.7 or 3.2 volts at a given mode, then the buck part of the magic can run it more efficiently and with less heat, giving you better run time from the battery…..then on the flip side when the battery is depleted enough to not be able to give the voltage needed, the boost part of the magic can do its thing and keep the light running for awhile. It’s a great design but they are kinda rare these days (easier to find them in expensive lights than it is to just find the drivers for sale separately).
So in picking a driver, you first need to know the power source voltage delivered, and then the driven component voltage requirements…and go from there. One cell (or cells in parallel), two or more cells in series….and if the emitter(s) you want to use are 3, 6, or 12 volts (individually/parallel or in series)….then whatever else you need. Without buck or boost magic, you just work with the battery voltage as it falls, and small simple components like the 7135 regulator chips will do what they can until they can’t anymore. Buck/boost opens up many more options (which is great if power source is limited, like one single cell, and of course the other advantages no matter how many cells are being used).
CRC2
lol, I thought you had a pretty lengthy response in such a short time.
All good though. I got a bit confused there for a second. I have an M21B in the mail with the GTFC40.
When I quoted you “ As for the driver in your light, he says down the page that is has a max of 4.8 amps (4800mA)”
I was thinking that was referring to my M21B.
So it all made sense to me anyway. No confusion.
Correllux
Correllux's picture
8th grade typing class was either the best or worst thing I ever did. lol
I didn’t know that about the driver cats….that’s cool. I’ve wondered whatever became of Dr. Jones.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 37 min ago
He spends his time doing cat-scans.
Sari33
Last seen: 1 week 4 days ago
What kind of shield or filter is enought good to block the blue light emitted by LEDs? If I’m not mistaken I had read that the milky plastic that covers the bulbs has good shielding, really?
story
Last seen: 6 days 8 hours ago
I just received a SC64W. Is XHP35 Hi or XHP 35.2 Hi recommended for an emitter swap?
Lightbringer
Whut’s a Coacherella and whut’s a Billie Eilish?
Every time I hit the yootoob, they’re both alllll over like stink on a monkey. Damn, can’t escape!
raccoon city
raccoon city's picture
Last seen: 1 min 28 sec ago
Location: Palm Desert CA ~ West Coast is the best coast
The Coachella Music Festival is a huge music concert over by Palm Springs.
It was last weekend, and it'll be next weekend as well.
The last time they had it was in 2019 due to the pandemic.
It's quite expensive to go, but tons of people from Los Angeles come to the Coachella Valley for the festival.
It brings a lot of money to the valley, but also a lot of traffic in certain parts.
EDIT:
By the way, I live in the very southern tip of Palm Desert, and Palm Desert is right in the middle of the Coachella Valley.
Ledhead
Ledhead's picture
Last seen: 6 hours 47 min ago
This isn’t the same Dr. Jones….is it?
:stupid Q’s:
CRC2
Not a clue.
But I only see my subscriptions or my search results.
I dont see what youtube displays on the homepage.
Ledhead
Ledhead's picture
Sorry ‘bout that.
What is considered a “cycle” when charging a battery?
If I take it off the charger before fully charged then stick it back in.. have I started a new cycle?
Sidney Stratton
@Ledhead;
Technically, a cycle is a complete charge. ie, you charge at 20%, another time at 30% and then another time at 50% would be 100% or 1 cycle.
As we can’t tally these times, ballpark figure of how many times you would have completed the charging.
Lightbringer
Mmmm, I got the impression it was a sort of Woodstock for the hoity-toity.
Never heard of it before, but lately it’s been inescapable.
And Billie Billie Billie, yeah, I get it, she’s getting pushed… hard… but no idea why.
raccoon city
Yeah, it kinda is.
Most people that go to it either get drunk or stoned and then enjoy the music all weekend long.
Lightbringer wrote:
Never heard of it before, but lately it's been inescapable.
It's one of the biggest music festivals in the U.S.
I like music, but I wouldn't go to a music festival even if someone paid me to do it.
(I'm not a people person and I don't like standing for long periods of time.)
pennzy
pennzy's picture
Last seen: 2 hours 18 min ago
Yeah, standing for hours is tough at my age but the worst part of concerts today is standing next to a 12 year old and their dad. Kinda ruins the experience.
Lightbringer
Nope, nope, not saying it… Evil
xevious
xevious's picture
Last seen: 7 hours 49 min ago
Weed for recreational use just became legal in NJ. It’s still not in NY and CT… so you know, this is like a cocktail for disaster. While it should be treated like smoking in public venues, where smoking cigarettes is not allowed (restaurants, stores, buses, trains, etc.), I have a feeling we’re going to be smelling the stuff much more often. Since wearing masks has been normalized by COVID, I see this will be another reason to wear ‘em. Second hand marijuana smoke is worse than cigarette smoke, according to CDC.
Btw, heard an NPR program about cannabis related issues. There was a woman who had worked for a company over 20 years and was nearing retirement, and a nice pension. She fell in the office due to unexpected debris. She was given a drug test at the infirmary and failed for THC. But she wasn’t using it recreationally. It was medical marijuana, which has very low THC so no mental influence. Her doctor had recommended it, but didn’t have an official prescription. Her boss had to fire her, because of the tight drug policies of the company. He didn’t want to do it, but was compelled because of the company’s laws. She lost her pension and because of the reason, couldn’t get another job. I think that’s such an extreme and unfair punishment, and I wonder how many other policy timebombs are set to trip up people who use cannabis recreationally. This has happened a number of times, purely by medical use of cannabis. HERE and HERE, for more examples.
Anyone else here see this legalization trend to be another one of those spaghetti against the wall decisions due to public pressure?
pennzy
pennzy's picture
It’s legal in NY now also. Stores haven’t opened yet though. The US House passed a bill to legalize it but the Senate probably won’t. Pa gives it a lot of lip service but typically no action.
A lot of laws will need tweaking now concerning driving, gun ownership, work.
raccoon city
Marijuana has been legal in California for a while.
Considering it's probably one of the safest ways to get high, it's fine with me.
I think it's safer than alcohol or tobacco.
The one thing I don't like is that people sometimes drive while high.
Although it's not legal to do so, because weed is legal when you're not driving, it happens more frequently now.
xevious
xevious's picture
That's the thing. You can measure your blood alcohol level with a simple breathalyzer test. I don't see anything equivalent for THC that doesn't require taking a blood sample. That's a real problem.
Also the nuances of getting high off of cannabis is different from alcohol. Whereas alcohol effects are rather homogenous and predictable, it's not the same with THC. I drink and rarely do it to excess. But when I've had a few, I know exactly how I feel and whether or not I'm safe to drive. I'm not a stoner and I don't do pot any longer because I just don't enjoy it. But when I did... gauging the effects was difficult. The "stoned" feeling doesn't wane on a predictable curve. It can "wobble."
Some people hallucinate under THC. Some don't. Some experience personality aphasia, most don't. That's the really dangerous thing about it. The very wide range of ways it affects people's minds.
pennzy
pennzy's picture
It’s not like pot isn’t already available if you want it. The people that waited for it to become legal before trying are not apt to drive under the influence. Maybe a small increase in abuse. Frankly, I am more afraid of people driving under the influence of cellphone.
raccoon city
What's annoying is that buying weed illegally is cheaper than buying it legally.
I quit vaping and smoking in 2011, but it's still true today.
xevious
xevious's picture
pennzy wrote:
It's not like pot isn't already available if you want it. The people that waited for it to become legal before trying are not apt to drive under the influence. Maybe a small increase in abuse. Frankly, I am more afraid of people driving under the influence of cellphone.
I agree. That happens far more than DUI of substances.
Yep. The extra middle men and the state all need to take a piece now. However, growing it is relatively easy, given how cannabis is like a weed. I'll bet growing it without a license to do so is considered a crime, but in very small quantities (for yourself and friends, not for resale) I doubt police could be bothered.
CollectEverything
CollectEverything's picture
Last seen: 7 hours 7 min ago
My brother is enjoying and using the lights we got him for his B-day (M3-C, FC11) but he’s still looking for one that’s shaped like a Sofirn SF47 He doesn’t actually want an SF47 because he thinks the beam is too floody. And he doesn’t want a mult-switch design. (ruling out the SF47T)
Put plainly, he’s looking for:
  • 2 × 21700 in series (for form factor reasons)
  • smallish head/reflector (approx 2 inches)
  • somewhat focused beam (I think he hates flower petal beams too)
  • single button interface.
My Collection
CRC2
Im looking at picking up a D4SV2. Probably the dual channel version.
Its not going to be half as bright as the regular D4SV2 (using four of the same LED) is it?
Edit: Dual channel 5000k LH351D’s vs a single channel with 4 × 5000k LH351D’s
If I were to decide I dont like the 2nd channel very much, and end up primarily using it on the LH351D channel. Would I be gaining or losing anything compared to the single channel 4 x LH351D’s?
I think It would be nice to have the W1’s in the second channel, but also think its possible it wont be as useful as Id like.
Curious if I should just write that idea off now and go for a single channel with 4 × 5000k LH351D’s.
