ALL FREEMEšŸ€ x 1THEDEALS Group Buy >> HOT āœŒ EC01X/ EC07/ ED01/ EA01/ LT2 āœŒ
Ok, Iā€™ve donā€™t reply to @robocop at page 4
But for me I donā€™t trust Neal info from Nightwatch, the pair is explosive for unvolontary mistake
Iā€™ve change alu bezel for steel bezel without hesitation, for me no alu bezel for this light.
  1. tactical_grizzly mentioned 20000lm with P42A.
  2. You can order stainless steel bezel together with the light
  3. Samsung 30T/ 40T.
Problem with Li-ion discharged below roughly 2.5 V is that you donā€™t know if dendrites started to form. You might ā€œrecoverā€ the battery just fine, but in a few days or weeks it might just catch fire by itself. Internal resistance, self discharge, voltage curve ā€“ nothing will indicate that the battery is damaged internally. Iā€™d say it is just too risky to try to save a few bucks. Take your loss and dispose them.
Since the batteries I bought for this light are potentially toast, Iā€™m using another set of P42Aā€™s now and with these Iā€™m getting up to 22,000lm @turn-on. A 10% increase. Neat.
Ho my god, Iā€™ve try it at my windows :smiley:
Il like the beam, massive and powerfull hotspot and wide spill , think similar to astrolux MF01S, around same size but less bright, more spill bright, I like.
The building a 200 meter full illuminated.
Wow if the cooling fine do job , damn, medium mode seem be good too.
Iā€™d really like to test it tonight :weary:
Great word, just ask for 2 new cell and no new driver.
In memory of the two P42A low volted
Nice! Test some 30T next of you can. Iā€™d be interested to see what those do!
Erratum high stupidity.
Absolutely nothing similar with MF01S beam :person_facepalming:
Finally Iā€™ve try them
In quick word, That light is an Astrolux EC06 purged of EC06 fantasy (USB-C first , button at head second, tripod mount at third) and purged of all Astrolux shame, a body full useless with massive weight and tiny head so light without passive cooling.
Nightwatch NS59V1
Astrolux EC06
Acebeam X45 (5000k)
Astrolux MF01S (5000k)
No more value to this nighsot, just same setting for compare, iā€™ve can do focus elsewhere than on the tree, Ive planed other spot but without focus enough for tonight
Iā€™ve do quick video at same pot, release later.
Astrolux EC06 is a shame.
Few thing after this night
I love low- medium outpout well spread (see on picture near EC06) but especially sustainable :cry:
I donā€™t by Nightwatch light with XHP50.2 NSX4 for example too much power, I prefer NSX4E with SFS80 led (7000 lumens claim compare to 14000 claim for XHP 50.2) more throw with less lumens for better perform
On this light I donā€™t expect good beam for medium output but finally equal my NSX4E at high with high reserve of power
160 beam angle at feed with pretty nice hotspot, no big artifact, petaling, other
I donā€™t take my NSX4E for tonight and I need to try with it for confirm.
Turbo is useless high, compare to turbo with naked eye, you see difference but you donā€™t feel it too much, for higher heat generation, this light have same perform at turbo compare to EC06 (with relative low output)
On high, overperform EC06
Medium :crown: .
Cooldown pretty nice heat sink do the job.
Over my hope low is pretty hig :smiley:
In fact I love the space between each step, moon-low-medium-high for example 25% more output at each step with high base output, I like it.
Turbo on Nightwatch is always near high, but for light I like in Nightwatch is ā€œlowā€ output > 7000k lumen, so for this output the pretty high passive cooling of Nightwatch light do the job and you can abuse of turbo.
But for this light, Turbo is overpower, but in high you some little output power but get more durability.
For me medium is pretty wonderfull high angle beam and large hotspot no to high, no self blinkink, sustainable mode > the best.
High is pretty power output with raisonable sustain, nice to use.
Low mod is very bright, if you like moon or low output, not on this light
Moon, pretty high output, not moon clearly and not the best I prefere low
The head :blush: say previously this reason in like Nightwatch host, no USB port, no button, nothing, head is here for take heat heat and heat and evacuat heat by cooling fine, a LIGHT, simply, not piece of shit with horror design for put glow tube inside and get shit perform :slight_smile:
Hard low voltage warn (or heat) I was walk in turbo for try overheat and hard step to low mode, I change cell and test after back in my house, 3.45 volt, so I think low voltage warn.
40T no function inside without modification in head for make contact
P42A function, but have lot shacking inside and create lot of interuption, Iā€™ve put inside a metal washer at the back and resolve interuption, but we feel shack inside, I think I rewrap my cell for more thickness.
Two O-ring at the top and the back :open_mouth: first time I see light with 4 O-ring, but no more in package for change.
Iā€™m very enjoy for this first night, I want to use more with various light to compare , but my first impression was exellent.
Vodak-Yarout, a really good perspective on this light. Iā€™m agreeing with everything including most of the comments on the Astrolux EC06. Side switch a needed sin but dump the port and tripod mount. The Nightwatch NS59V1 turbo is really asking way too much from only 2-21700 batteries. The rest of the light seems good.
On my LVP issue, Neal relayed from Nightwatch that P42Aā€™s are ā€œnot goodā€ for NS59v1. He is sending me some of the ā€œspecial batteriesā€ he has specifically for this light. If they fix the issue, I will pay for them. I am dubious that it will make a difference, but I will test them and report back. Does anyone have an explanation as to why LVP built into the driver would work with some batteries (Neal mentioned 30Tā€™s & 40Tā€™s) but would not work with others (P42Aā€™s)?
I ordered mine with the batteries so when I get it Iā€™ll post what batteries they are. Itā€™s a couple states away but hasnā€™t had a tracking update in a couple days. Iā€™m not going to test if the lvp does in fact work with those batteries because they werenā€™t cheap. Unless someone can suggest a safe way to test without actually draining the batteries.
Awesome! I look forward to seeing your results.
The safest way to test would be with a bench power supply. Alternatively, you can drain the batteries separately in another light down to LVP level (~2.7V or so). Then try them in the Night watch for a couple minutes on the lowest mode. It shouldnā€™t drain them too far but it should make LVP kick in if it does indeed have LVP.
Okā€¦ I finally pulled trigged and ordered one. Lets see how this LVP goesā€¦ and maybe see how some Vapcell T42 do in it. I might even try to get my hands on Vapcell T40s to see if those can push the emitters harder, @ 2000mah theyā€™ll die pretty quick Iā€™m guessing.
I have a bench top power supply at work I can test it with. Didnt even think about that. When it comes in Iā€™ll bring it to work and check it out. Freeme says below 5.6v should auto shutoff so it should be pretty quick to verify. Just need to get my hands on the light first
Actually going to be a bit longer for me to test this out. I got my tracking information mixed up with my convoy order. My ns59v1 is still tracking as in China. But I will test as soon as I get it if no one else has yet.
Does anyone have sustainable output numbers for this light? Runtimes? A beamshot would be nice too.
Will include all that in my full review. For now based on the one runtime test Iā€™ve done, Iā€™m getting just under 2000lm sustained for about an hour and a half on P42Aā€™s.
The thing with P42A from observations with other high current lights, is the 30/40T can ha dle higher initial current loads than the P42A can. Itā€™s as much as 15% higher vs a 30T, which is a lot.
The writing on the switch looks like ā€œOmten PBS101ā€ according to Omtens website itā€™s rated for 3 Amps at 30 Volts, i wonder how it will hold up
Thatā€™s a pretty robust switch good to see a name brand in there too. Itā€™s also meant for AC 125V and 1.5A so that gives you an idea of itā€™s rated capacityā€¦about 190 watts on AC and probably 60 A on DC.
