My orange LT1 (box labelled Q8LT1) from Sofirn’s AliExpress shop shows BLF-LT1-A4. One difference from the BLF-LT1-A2 is that the indicator LED is now orange. Perfect. Any other differences?
I love how the indicator LED automatically adapts to the main light’s brightness: dim at low brightness, and high at high brightness. Such attention to detail, just fantastic!
The orange anodizing looks gorgeous to me. It looks slightly bronze-ish in some images below due to the camera, but it’s more orange in person. I was also very tempted by the green option, but figure a more visible color is useful to avoid losing it!
Some questions:
The only way I found to get out of momentary mode (5C from ON or OFF in Advanced UI) is to unscrew the lantern until power is cut. Is there another way? The UI map shows this mode is a dead end.
Sunset mode is reducing brightness in steps, even if the light is set to smooth ramping. Any way to have it decline smoothly?
It’s surprising how pleasant and nostalgic candle mode is, especially in the warmest tint.
Big thanks and congratulations to all involved in the LT1 project!
Ah, makes sense, and in that case it’s actually a cool feature. The UI diagram should probably still indicate how to exit this mode, even if it’s physical vs electronic.
Other observations:
2H from OFF in Advanced UI is a turbo momentary, unlike what the UI map shows.
The ramping seems to go all the way to max/turbo level. Maybe I misunderstood, but it seems the UI map shows ramping or 2C to reach the ceiling level, then a further 2C for turbo. Instead, a second 2C just returns to the previous brightness for me.
Btw, I’m looking at the 2021-08-02 revision of the UI map for the LT1.
As the saying goes, the biggest room in the world is the room for improvement. Fading in steps is a bit jarring, but I’ll survive.
The floor and ceiling levels are configurable. On the LT1, the default is to allow full power because it’s not a hotrod light. This can be changed though.
About fading in steps, it’s mostly because of the power circuit having coarse resolution at a hardware level. I’ve been thinking about ways to work around that, but the only solution I’ve come up with is really complicated and would require pretty major changes to the code.
Basically, the hardware allows for 256 total steps including “off”. When the light is at level 5/255 and needs to fade to 0 over the course of 5 minutes, it’ll slowly drop to 4 then 3 then 2 then 1 then shut itself off. These steps are quite visible.
To fix it, I’ve been thinking about making it alternate between levels very quickly, like at 16 kHz. So instead of dropping from 2 to 1 all at once, it would go 22221 for a while and then 21221 for a while, then 12121, then 11211, and then just 1. And each step there would last for only a fraction of a millisecond, so it would hopefully look smooth by eye. But to make it work, it would need extremely precise, consistent timing, and a bunch of math, and some core parts of the code would need to be completely rewritten.
So… for now, the steps are still visible during low modes.
At high levels, it doesn’t matter. Dropping from 240 to 239 isn’t a visible difference. But dropping from 3 to 2 sure is.
I see, so that’s what it means when the UI map mentions that the factory default ceiling is 150/150. Now it makes sense. I confirmed that turbo works as expected if the ceiling is reduced. Interesting, and ultimately the default makes sense.
Thanks for that explanation. The proposed solution sounds clever. Before even trying to implement it in Anduril, has the eye’s perception of this strategy been tested?
In any case, it’s already amazing how much Anduril can do and how it spices up the LT1. Thanks for your efforts.
Can anybody help me out? I have been gone for so long that I don’t even know if I had a user name so I had to create a new one. I was here when this project started, but never bought the lantern. I am getting ready to buy one or two and the mini later. What is the current status of a 21700 version, distant future? Should I just get the current version? I am a bit confused on their Ali store because I remember the whole problem with the USB-C and want to get the latest version. I assume that is the one listed as New Anduril 2? The price is really good right now! Thanks for any help in advance.
There has been some discussions on a 4 cell 21700 version but not much more than that. If it was me I’d get the current version because it could be some time before a decision is even made on producing one.
Thanks for the reply. I decided on one plus 2 of the LT1S and a flashlight. Now I am remembering why I never order… they never have the pretty colors they show.
3*21700 in the center of a Nalgene sized, full-body diffuser with a third red channel in addition to the two tint ramping white channels. Waterproof and floats.
I recently ordered a second LT1 from Sofirn which UPS promptly lost, so they sent me a brand new production light to replace it. This one is a BLF-LT1-A4 driver with the wonky flashing pad configuration, Anduril version 202108290621. The switch backlight is orange by default, and uses a blue/pink combo for charging and power bank, or solid blue while on and plugged in. It gets stuck using either blue or blue/pink while on for a little while after being unplugged.
This particular light arrived with a weird issue where the tint ramping didn’t work properly. It didn’t memorize the setting at all so it always turned on in WW, but every second turn-on it would go through a sequence where it immediately flipped to CW on the first attempt, flipped back to WW and smoothly ramped to CW on the second attempt, then worked properly on following attempts. A factory reset solved that issue and TK told me it was probably caused by incorrect values causing an overflow. Of note, 13H factory reset doesn’t work in this Anduril build, which was rather confusing since it’s included in the UI flowchart.
Loosen tailcap (or in this case, the battery tube)
Hold the button
Tighten tailcap
Keep holding button until the strobing turn into a bright flash (about 3-4 seconds), then let go
If the user lets go before the flash, the factory reset is cancelled. It strobes in increasing intensity for about 3 seconds as a warning, sort of the flashlight equivalent of “Are you sure?”. Then it goes to full power to signal that the reset happened, and it quickly fades to off.
The factory reset animation originally came from my lightsaber firmware. It did the same thing, but in that UI, instead of “factory reset”, it was called “self destruct”.
Installing the new driver in an older LT1. But when screwing on the battery tube, it goes on full brightness and pressing the switch has no effect. The green switch LEDs toggle between dimmed and full on when pressing the switch. Anyone has any idea what might be causing this?
Update:
Solved. When putting it back together the CW wire ended up being squeezed and the insulation broke causing a short (direct battery connection?). Seems there’s no permanent damage… phew…
Are the switch PCBs interchangeable? The green that comes with the new A2 driver is pretty annoying, so maybe the old switch board (rev 5) can be used instead. Has anyone tried this?
Unrelated, how many different flashing pad layouts has Sofirn come up with by now? I think they’ve earned a trophe from coming up with the most variations.
