Just ordered one with batteries and SS bezel, thanks FREEME.
Also grabbed an Amutorch XT60 SFT40 while I was at it, discount code applied to the XT60 as well, paid $64.46 with battery…
Got my “CHAOS” flashlight this afternoon.
The package didn’t include any “O” rings, lanyard, or manual. But there are two “tactical” aluminum rings.
Put in two flat-top 21700 Wurkkos batteries together with a Convoy 21mm spacer on top. And it works OK. The powerful beam is floody.
I wonder what brand of 21700 button top batteries with 40A discharge rate you will get if ordered them together with this flashlight. Not easy to find button top batteries with such high discharge power.
The body can be separated into two shorter tubes. But when putting in only one battery cell, the flashlight doesn’t work. Need to put in two battery cells.
Very good, I use those to convert my Vapcell T42 from flat-top to button-top
Could someone please post a link to the mentioned 21mm Convoy spacers?
I placed one of these between two 40T cells and it seems to work well.
Thanks JordanZHP.
Could I have the coupon please Freeme?
The coupon is in the first post right under the discounted prices
Got mine today. Thanks Freeme!
The batteries that are included in the package aren’t actually button tops. They’re flat tops with a small copper (?) Disk soldered on.not sure what type of 21700 they are. they have a dark grey wrap and say “21700hp 3.7v 3000mah 20c”. They came pretty low charge so they’re on the charger now.
i can test the lvp on this light next week with a PS at work.
RIP our cell if you try
Strange cells O_0 you have a picture for share?
It’s would be sad to damage “special” cell
Yeah I’m going to use a bench top power supply and see how low I can drop the voltage. Hopefully it’s simple and doesn’t damage anything. Also hopefully this picture of the battery uploads right. If not here’s the link
Ho, sorry, I’ve forget it’s you who have say he can try with external power supply.
Normaly no, just open the circuit
Thank’s for sharing
Strange “custom”, If they works
Never see button top solder in this way.
HP remember Nitecore classification cell, same cell with same capacity with various head, HP/HPI ….
Holy crap! Has anyone confirmed this light actually has temperature control?it gets too hot to hold and fast! Love the amount of light but I’m going to need gloves the next time I use it.
@madcrisis, the temperature control does work, but I think I saw one of TacGriz’s post and the temperature at which the flashlight throttles is rather high.
To be honest though, this was not unexpected: you’re consuming about 200W+ on turbo, which mean passive cooling in this form factor is out of the question.
Lishen 21700HP
NS59v1 was a HUGE hit at the Texas Flashlight Club meeting tonight. It blew everything else we had (MF01S, MF01X, X50 CRI) out of the water.
Cant wait to get mine! :sunglasses: What cells were you using?
To be fair, I’m sure the X50 CRI has a rather significant advantage over the NS59v1
I’m using P42A’s I salvaged from a dead X50 battery pack right now. I’m getting 22,000lm @ turn-on with those. Neal is sending me some of his “special” batteries that will allegedly fix the fact that my sample does not have LVP. I’ll measure output with those too.
And vice versa, since one is 1/4 the price of the other. Here are beamshots if you want to take a look.
NS59v1 & X50 CRI
MF01S 6500K & MF01X
These really don’t capture just how wide and bright the spill is from NS59v1. That’s the most impressive thing about it.
Well maybe, but for the price? No way. I have one hopefully coming for review (if Neal gets around to sending it). On paper, this could be the most powerful affordable flashlight ever. 28,000 Lumens for under $100 is insane. I actually believe Nightwatch Lumen numbers…the NI03 I tested got super close to advertised, off by 150 lumens and I think this will get close to 25,000 on 30ts.
